Fairphone 4 OS manual installation with macOS
First, complete all the steps from the article Fairphone 4 OS manual installation.
Apple macOS Monterey 12.2x Process
- Once your Fairphone 4 is in Fastboot mode, connect it to your computer using a USB-C certified data cable.
- Locate the archive you downloaded in the previous step, (usually in the Downloads folder).
Open Chrome Browser.- Press simultaneously the keys Alt ⌥ (option) + Cmd ⌘ + L. A new tab called Downloads will open.
- Look for the last download, the name starts with FP4. Click on the writing Show in Finder.
A new instance of Finder will open.
- Open (Double-click) the archive you downloaded, the name starts with FP4.. The files will be extracted in a folder with the same name. Wait for it to be completed.
- Once done, simultaneously press the Cmd ⌘ + Space keys. Spotlight Search will open.
- Write Terminal.app, then press the Enter ↩ key.
- In the Terminal window, type
cd
then press space. - Drag the folder extracted previously inside the terminal window, and press the Enter ↩ key.
- Type
./flash_fp4_factory.command
If a similar error message appears:
Click on OK.- Go to the Apple menu (top left corner of the screen) →System preferences....
- Click on the icon Security & Privacy.
- Click on the General tab.
- Click on Open Anyway.
- Now, go back to your Terminal window.
- Type
and press the Enter ↩ key. - The following warning will appear:
Type inYes
and Press the Enter ↩ key - The script will now run for a couple of minutes like in the following picture
Once done, you will see the following picture
-IMPORTANT-
It can take up to 15 min. Do NOT interrupt the process, it might damage the device! - Done, your phone is now up to date. Your phone will now reboot, finishing the system update for a few minutes. You can now safely unplug your Fairphone 4 from your computer.
- Once done, for safety reasons, we strongly advise you to lock your bootloader again. To do so, follow the instructions in the article Manage the bootloader.
