Troubleshoot the Mobile data connection
If you are having issues connecting to Mobile data on your Fairphone, make sure to read the article Connect to Mobile data. There, you'll find instructions on how to enable Mobile data on your Fairphone.
If you are still having issues after going through the article, proceed with the next steps.
Update
Make sure that your phone is up to date.
If you are not running the latest software, or you are not sure, update your Fairphone to the latest Fairphone OS.
Check your mobile network
Make sure that your Fairphone connects to the right network provider:
  1. Go to Settings → Network and Internet → Mobile Network. If needed, select the tab related to the SIM card you are troubleshooting.
  2. Make sure Mobile data is enabled. You might need to enable Roaming (check with your provider as this may incur additional costs).
  3. Tap on Advanced (only on Android 10 and 11) and disable the option Automatically select network. The phone will scan for all available operators, and this might take a bit.
  4. Manually select your network operator. If your data connection starts working, you might have been registered on the wrong network before.
    In case of roaming, you can check with your operator which foreign networks will work best for you.
Mobile internet settings (APN)
Reset APN (Access Point Name)
Try resetting your APN(s) to their default. You'll need to do that separately for each SIM card you're using, including eSIMs.
  1. Go to Settings -> Network & Internet.
  2. Select your Mobile Network.
  3. Tap on Advanced (only on Android 10 and 11).
  4. Scroll down all the way and tap on Access Point Names.
  5. Tap on the three dots in the top right corner and tap on Reset to default.
  6. Test again.
    If this didn't help, you can also check with your operator whether you need to manually set your APN settings.
Manually set APN(s)
For a minority of network providers (usually some newer MVNO), you will have to set your APNs manually. Contact your provider and ask them to help you set up the APNs.
  5. Tap on the plus symbol "+" icon located in the top right corner.
  6. Tap on the field you want to edit.
  7. Select or type in the value you obtained from your network operator, then tap on OK.
    Repeat this point for every parameter you have.
  8. Once done, tap on the More options icon (three vertical dots 3dots_icon.png) in the top right corner, then tap on Save.
  9. Reboot your device. If your contract includes Mobile data, you should now be able to connect to the internet.
We also recommend consulting the forum of your provider to see if similar problems are mentioned.
Set your data to a specific network type
If you are still not connected, try different connection protocols (5G/4G/3G/2G).
For maximum performance, always enable the highest possible option - 5G for Fairphone 4 and 4G for Fairphone 3(+) and Fairphone 2.
  4. Tap on Preferred network type.
  5. Select the connection protocol you'd like to use.
Check your SIM card
In case you have a physical SIM card, we have a guide on how to Troubleshoot the SIM card(s).
If the issues persist, or in case you use an eSIM, the phone might be trying to connect using a network protocol that is not supported by your contract. Contact your provider for more information.
