Important Notice: On 19 May 2024 at approximately 19:30 CEST, our system sent out order confirmation emails for previous purchases. These emails were sent in error.
Rest assured, no new orders have been placed on your behalf, and your account has not been charged. We apologize for the inconvenience.
★ How to use your Fairphone
Learn how to set up a few basic features and start using your new Fairphone.
For a quick video introduction, choose your phone below:
Getting started
Turn your phone on and off
To turn your phone on:
  • Press and hold the Power button until the display lights up.
To turn your phone off:
  1. Press the Power button to turn on the screen.
  2. Press and hold the Power and Volume up buttons at the same time.
    (On some Fairphones, press and hold the Power button).
  3. On your screen, tap Power off.
You can change what happens when you press and hold the power button:
  1. Go to Settings → System → Gestures.
  2. Tap Press and hold power button.
  3. Choose from:
    • Power menu.
    • Digital assistant.
Download and manage apps
If you have a Google account, you can download and install apps through the Play Store:
  1. On your phone, swipe up from the Home screen to see All Apps.
  2. Look for Play Store and tap to open it.
  3. Find an app you want.
    Tip: Look at the star ratings and number of downloads to check if the app is reliable.
  4. Tap on the app you want to download.
    • If it's a free app, tap Install.
    • Otherwise, tap on the price.
Remove or disable an app:
  2. Tap and hold the app you want to remove.
  3. Tap App info Uninstall.
    (If you only see Disable, it's a system app. You can't remove system apps. If you disable a system app, Android and other apps may no longer function as intended).
Personalisation
Change your wallpaper
  1. Go to Settings → Wallpaper and style.
    Or, touch and hold an empty space on your Home screen and tap Wallpaper and style.
  2. Tap Change wallpaper.
    • Tap My photos to use your own photo.
    • Or tap On-device wallpapers to use images that come with your phone.
  3. Tap Done and choose which screens will show your wallpaper:
    • Home screen.
    • Lock screen.
    • Home and lock screens.
Change your ringtone
  1. Go to Settings → Sound → Phone ringtone.
  2. Tap on a ringtone to listen to it.
  3. Press OK to confirm.
Sound settings
Your Fairphone has three sound settings:
  • sound.png Ring
  • sound_vibration.png Vibrate
  • sound_no.png Silent
To switch between modes, press a volume button and tap the icon above the slider.
For additional settings, press a volume button and tap the three dots below the slider.
Communication
Make and receive phone calls
You can make calls using the Phone app:
  2. Look for Phone and tap to open it:
    • To call a contact, tap Contacts.
    • To enter a number, tap the Dialpad.
    • To call a number you recently called, tap Recent.
When you receive a phone call, the caller's number or contact name will show on the screen.
  • To answer an incoming call:
    • If your phone is locked, swipe the phone icon up.
    • If your phone is unlocked, tap Answer.
  • To decline an incoming call:
    • If your phone is locked, swipe the phone icon down.
    • If your phone is unlocked, tap Decline.
Send and receive text messages (SMS)
You can send and receive text messages using the Messages app:
  2. Look for Messages and tap to open it:
    • To start a new conversation, tap Start chat and type a name, phone number or email.
    • Or, tap an ongoing conversation.
Set up your email
Gmail is the default email app on Android.
If you have a Google account, you can send and receive emails using Gmail:
  2. Look for Gmail and tap to open it.
  3. Follow the setup process.
You can also add a non-Gmail account to the Gmail app:
  1. On your phone, open the Gmail app.
  2. In the top right, tap your profile picture.
  3. Tap Add another account and choose the type of account you want to add.
  4. Follow the setup process.
Other tips
Take a screenshot
  1. Open the screen you want to capture.
  2. Press and hold the Power and Volume down buttons at the same time.
  3. At the bottom left, you'll see a preview of your screenshot.
Scan a QR Code
You can scan QR codes using Google Lens:
  1. Open Google Lens:
    • On your Home screen, look for the Google Search bar and tap the Google Lens icon.
      Tip: On Fairphone 4 and 5, you can also access Google Lens from the Camera app by tapping the Google Lens icon between the preview and capture buttons.
  2. Point your phone's camera at the QR code.
  3. Tap the shutter button to open the link.
Language settings
To change the language for the whole device:
  1. Go to SettingsSystem → Languages and input.
  2. Tap Languages → Add a language.
  3. Choose your preferred language.
    Tip: If you have more than one language, drag your preferred language to the top of the list.
To change the language of an individual app:
  2. Tap App languages and select the app you want to change.
    (You can only change the language for apps that support language selection).
To change the language of the keyboard:
  1. Go to Settings System → Languages and input.
  2. Tap On-screen keyboard and select the keyboard you want to change.
    (Gboard is the default keyboard app on Android).
  3. Tap Languages Add keyboard.
  4. Choose a language.
  5. Choose a layout.
  6. Tap Done.
Adjust your brightness
Adjust your brightness manually:
  1. From the top of your screen, swipe down twice:
    • To lower brightness, drag the brightness slider to the left.
    • To increase brightness, drag the brightness slider to the right.
Adaptive brightness automatically adjusts your screen brightness to your environment and activities. Turn Adaptive brightness on or off:
  1. Go to Settings Display.
  2. Tap the Adaptive brightness toggle to turn it on or off.
    Tip: You can still move the slider manually to help adaptive brightness learn your preferences.
Quick Settings
You can find Quick Settings from any screen on your phone:
  1. Swipe down from the top of your screen to see the first few settings.
  2. Swipe down again to find all Quick Settings.
  3. Tap a setting to turn it on or off.
To move, add or remove a setting:
  1. From the top of your screen, swipe down twice.
  2. At the bottom left, tap Edit (pencil icon).
  3. Tap and hold the setting:
    • Move: Drag the setting to where you want it.
    • Add: Drag the setting from Hold and drag to add tiles.
    • Remove: Drag the setting to Drag here to remove.
