How to replace my Fairbuds Charging Case Battery?
Is your Fairbuds charging case struggling to power up, or not giving your earbuds the boost they need? Before you consider a new case, remember Fairphone's dedication to sustainable design! Just like your Fairbuds themselves, the charging case is built with repairability in mind. This guide will walk you through the straightforward process of replacing the battery in your Fairbuds charging case, ensuring your music stays charged and helping you reduce electronic waste.
-IMPORTANT- Before starting any repairs, ensure the Fairbuds are not charging or connected to any devices via cable. Work on a flat, stable surface. Properly dispose of old batteries by recycling them locally.
Steps to replace Fairbuds Charging Case Battery:
- Accessing the Battery
- Remove the screw from the bottom of the charging case
- Open the cover and remove the charging case core
- The battery is located at the bottom of the core
- Swapping Batteries
- Remove the old battery from the core
- Insert the new battery
- Place the core in the outer shell and secure the cover and tighten the screw
