How do I replace my Fairbuds outer shell and core?
Accidents happen, and sometimes the outer shell or even the core of your Fairbuds might need a refresh. But with Fairphone's commitment to longevity and reducing e-waste, a damaged part doesn't mean your Fairbuds are ready for the bin! This guide will show you how to easily replace the outer shell and core of your Fairbuds charging case, ensuring your earbuds remain protected and fully functional for years to come.
-IMPORTANT- Before starting any repairs, ensure the Fairbuds are not charging or connected to any devices via cable. Work on a flat, stable surface. Properly dispose of old batteries by recycling them locally.
How to replace the the Outer Shell and Charging Core Components:
Outer Shell
  1. Remove the core screw and outer shell cover
  2. Take out the core and place it in a new outer shell
  3. Secure the cover and tighten the screw
Charging Core
  1. Follow outer shell removal steps and take out the core
  2. Remove the working battery and insert it into a new core
  3. Place the new core in the outer shell and reassemble
