Fairphone Back Covers
The Fairphone has an integrated Back Cover that acts as a battery cover.
It connects to the core module to contain all the other spare parts.
Interestingly, in the Fairphone 4, it hosts part of the NFC antenna.
In case you need to replace it, you can find a new one in the spare parts section of our online shop.
How do I remove and put back the Back Cover?
For The Fairphone (Gen. 6), to remove the back cover, we advise that you first power off the phone by long pressing the Power button. Depending on your settings, you might have to press the power button and volume up button together to access the power menu.
Next, place the phone on a flat surface with the screen facing down. Take off the lower back cover by removing the two screws on the top left and top right of it. Slide the lower back cover off towards the bottom. To put it back, slide the cover up and replace the screws.
For The Fairphone (Gen. 6) back cover, go to:
How do I replace a spare part on The Fairphone (Gen. 6)?
For the Fairphone 5, Fairphone 4 and Fairphone 3/3+ back cover, watch this video:
What are the lower back cover specifications of The Fairphone (Gen. 6)?
- Made from 100% recycled plastic
- Only compatible with The Fairphone (Gen. 6)
- Color: Cloud White, Horizon Black and Forest Green
- Length 109.52 mm
- Width 73.27 mm
- Thickness 2.9 mm
- Weight 9.78 g.
What are the back cover specifications of the Fairphone 5?
- Made from 100% (post consumer) recycled plastic: polycarbonate
- Only compatible with Fairphone 5
- Color: Matte Black, Sky Blue or Transparent
- Length 158.2 mm
- Width 72.45 mm
- Thickness 3.35 mm
- Weight 15.8 g.
What are the back cover specifications of the Fairphone 4?
- It hosts part of the NFC (Near Field Communication) antenna
- Only compatible with Fairphone 4
- Color: Dark grey, Green or Speckled Green
- Length 160.6 mm
- Width 74 mm
- Thickness 3.5 mm
- Weight 15.8 g.
What are the back cover specifications of the Fairphone 3/3+?
- Dark translucent cover for Fairphone 3 and Black for Fairphone 3+
- Material: polycarbonate made with recycled plastics (version 1 with 37%, version 2 with 100% recycled plastics - available per July 12, 2021)
- Length: 158 mm
- Width: 71.8 mm
- Thickness: 9.89 mm
- Weight: 187.4 g
