Insert or remove a SIM card in your Fairphone
  • Updated
This guide explains which physical SIM card your Fairphone supports and walks you through inserting or removing the card.
If you want to use a digital SIM instead, read How to set up an eSIM.
Check SIM card and network compatibility
Check the table below to see which SIM card types and mobile networks your Fairphone supports.
Device SIM types Network support
The Fairphone (Gen. 6) / The Fairphone (Gen. 6+) Nano-SIM (1), eSIM (1) 5G, 4G, 3G, 2G
Fairphone 5 Nano-SIM (1), eSIM (1) 5G, 4G, 3G, 2G
Fairphone 4 Nano-SIM (1), eSIM (1) 5G, 4G, 3G, 2G
Fairphone 3 / Fairphone 3+ Nano-SIM (2) 4G, 3G, 2G
Fairphone 2 Micro-SIM (2) 4G, 3G, 2G
Tip: Replace a physical SIM card every two to five years. Over time, aging circuits can cause connection issues. Contact your mobile network operator to request a new SIM card if needed.
Insert or remove a SIM card on The Fairphone (Gen. 6) or The Fairphone (Gen. 6+)
You need the SIM card removal tool from the Getting Started Kit that came with your phone. If you cannot find the SIM card removal tool, use a toothpick or a safety pin instead.
Insert a SIM card
  1. Locate the tiny hole on the bottom edge of your phone.
  2. Push the SIM card removal tool into the hole until you hear a small click and the SIM tray pops out.
  3. Align the notched corner of your Nano-SIM with the matching corner on the SIM tray.
  4. Place the SIM card into the tray with the gold contacts facing up, and press down firmly until the card snaps into place.
  5. Slide the SIM tray back into your phone until the tray clicks shut.
Remove a SIM card
  3. Hold the SIM tray over a flat surface and gently lift the SIM card out.
  4. If the card is tight, push your SIM card removal tool gently through the small hole on the back of the tray to pop the card out.
Insert a SIM card on Fairphone 5 and older models
Follow these steps to install a physical SIM card on Fairphone 5, Fairphone 4, Fairphone 3(+), or Fairphone 2:
  1. Power off your Fairphone if the phone is turned on.
  2. Remove the back cover and take out the battery.
  3. Locate the SIM icon(s) inside the battery compartment. Never force a SIM card into the microSD slot, as doing so can damage your phone and void your warranty.
  4. Align the cut corner of your SIM card with the outline on the SIM icon.
  5. Slide the SIM card into the slot and press gently until the card clicks into place.
  6. Reinsert the battery and press the back cover back on until all edges click shut.
  7. Press and hold the Power button to power on your phone.
Remove a SIM card on Fairphone 5 and older models
Follow these steps to take out a physical SIM card from Fairphone 5, Fairphone 4, Fairphone 3(+), or Fairphone 2:
  3. Gently push the edge of your SIM card further into the SIM slot until you hear a click. Never use metal tools to pull or pry a SIM card out of the SIM slot. Using metal tools can damage the contacts and void your warranty.
  4. Release the SIM card so the card springs outward, then slide the card out of the slot.
  5. Reinsert the battery and press the back cover back on until all edges click shut.
  6. Press and hold the Power button to power on your phone.
If you're experiencing connectivity issues
If your SIM card does not connect to your mobile network, see Troubleshoot the SIM card(s) for step-by-step checks.
Still need help?
