What to do when your SIM card or eSIM is not recognized
  • Updated
If your Fairphone does not detect your physical SIM card or eSIM profile, running a diagnostic check can quickly locate the problem. Follow this guide to identify SIM issues, test your hardware, and resolve connection errors.
  • A physical SIM card newer than two years old, or an active eSIM profile from your mobile network provider.
  • An active mobile service subscription.
ⓘ These steps require Android 13 or later. Find out How to check and update your software version.
Identify SIM card issues
A malfunctioning, old, or damaged SIM card can cause network and performance issues. Common signs of a faulty SIM card or connection include:
  • The phone not recognizing the SIM card or displaying "SIM Card is missing".
  • Incorrect APN settings.
  • 4G and WiFi Calling not working on a supported network.
  • General connectivity problems.
A struggling network connection forces your phone modem to work harder, which can cause secondary symptoms:
  • Increased power usage and reduced battery life.
  • The phone becoming warm.
  • Random restarts.
Testing your phone with a SIM card newer than two years old helps isolate card issues. You can also test with a borrowed card from another network provider. Avoid testing your SIM card in another phone because SIM card slots vary across models.
How to run a hardware diagnostic test
If your phone does not detect your SIM card or eSIM, run a quick hardware test using the built-in Service menu.
  1. Open the Phone app.
  2. Dial *#*#8378#*#*. Once the last character is typed, the Service Menu appears (this may take a few seconds).
  3. Tap Menu and accept all permissions.
  4. Tap on SIM card and/or eSIM, depending on the card type you are testing.
  5. Check the test result on your screen:
    • SIM card is OK or ESIM is ok: Your phone hardware detects the card or profile.
    • SIM Card is missing: Your phone hardware does not detect the card. Test a different physical SIM card newer than two years old.
How to troubleshoot persistent issues
If the Service menu test or a replacement SIM card does not resolve the problem, try these steps in order:
  1. Remove the physical SIM card, restart your phone, and test device behavior without a SIM card inserted. If the phone works properly without the card, contact your network provider to ask for a replacement SIM card.
  2. Restart your phone in Safe mode to test whether a third-party app interferes with your network connection.
  3. Make a backup of your data and perform a factory reset. A factory reset clears persistent software glitches and is a required step before sending a phone to our repair center.
A factory reset permanently erases all personal data, apps, settings, and media stored on your phone. Create a backup of your important files before proceeding.
Still need help?
