How to replace spare parts on your Fairbuds
  • Region:Europe
  • Updated
The modular design of your Fairbuds allows you to easily replace spare parts and components yourself. This guide offers resources for replacing the earbud batteries, charging case battery, outer shell, charging core, or a lost earbud to keep your device working for longer.
If you are experiencing general issues with powering on, connecting, or using the basic controls of your Fairbuds, please refer to our Getting Started guide first: How to use your Fairbuds.
Replacement guides for Fairbuds
How to find the serial number of your Fairbuds
If needed, you can find the serial number on the original packaging. If you no longer have the packaging, remove the outer shell and battery from the charging case to find the serial number printed inside.
Still need help?
