Fairphone 5 release notes
Find the release notes for current and previous software versions.
Current software version
FP5.VT34.C.120
Release date: 23 November 2026
Android version:Â 15
Resolved Issues
- Fixed an issue where eSIM PIN page was no longer showing after enabling the SIM
- Fixed an issue where device reboots when long-pressing the volume down button
Other Improvements
- Security patch level: 05 November 2026
- Removed "Do not validate" option to prevent bypassing certificate validation for enterprise Wi-Fi networks.
Previous software versions
FP5.VT32.C.116
Release date: 21 September 2026
Changes:
- Security patch level: 05 September 2026
Â
FP5.VT31.C.114
Release date: 24 August 2026
Changes:
Resolved Issues
- Fixed an issue where device could not connect to 6 GHz Wi-Fi networks
- Fixed an issue where recent apps button was occasionally not responsive
- Fixed an issue where dark mode was disabled automatically when it is enabled outside of schedule
Other Improvements
- Connecting an external display gives user an option to Mirror or use Desktop mode
- General UI improvements
- Security patch level: 05 August 2026
Â
FP5.VT2Y.C.108
Release date: 20 July 2026
Changes:
- Security patch level: 05 July 2026
Â
FP5.VT2X.C.107
Release date: 29 June 2026
Changes:
Resolved Issues
- Fixed an issue where the speed on navigation applications was glitching.
Other improvements
- Simplified the bootloader unlock process.
- Security patch level: 05 June 2026
Â
FP5.VT2R.C.095
Release date: 18 May 2026
Changes:
- Fixed an issue where ring vibration strength was affected by other haptic settings.
- Fixed an issue where the three button navigation disappears when changing theme.
- General UI improvements.
- Security patch level: 05 May 2026
Â
FP5.VT2Q.C.092
Release date: 20 April 2026
Changes:
- Security patch level: 05 April 2026
Â
FP5.VT2P.C.089
Release date: 30 March 2026
Changes:
- Optimized background process management for smoother multitasking.
- Security patch level: 05 March 2026
Â
FP5.VT2M.C.084
Release date: 23 February 2026
Changes:
- Fixed an issue where fingerprint haptics were disabled by low touch feedback settings.
- Security patch level: 05 February 2026
Â
FP5.VT2K.C.076
Release date: 26 January 2026
Changes:
- Security patch level: 05 January 2026
Â
FP5.VT2I.C.072
Release date: 15 December 2025
Changes:
- Fixed an issue that resulted in the recent apps history not functioning at times.
- Fixed an issue that resulted in the message "SIM 1 is VoLTE capable" displaying on the device.
- Fixed an issue where ending a WhatsApp call on mute resulted in the microphones to be muted system-wide.
- Fixed an issue where a user set wallpaper is automatically reverted to default settings.
- Fixed an issue where the network name was appearing in the status bar even if disabled in settings.
- New version of MyFairphone App v4.2.13.
- Security patch level: 05 December 2025
Â
FP5.VT2F.C.065
Release date: 17 November 2025
Changes:
- Fixed an issue that resulted in the Dynamic app icons not displaying the correct information for date and time.
- Fixed an issue where fingerprint haptics were not functioning correctly.
- Fixed an issue that was resulting in Quickstep (launcher) to quit when using the "Saving app pair" feature.
- Fixed an issue that resulted in NFC not functioning correctly.
- Security patch level: 05 October 2025
Â
FP5.VT2E.C.059
Release date: 05 October 2025
Changes:
- Fixed an issue that prevented devices with a malfunctioning fingerprint sensor from booting into Android 15.
- Security patch level: 05 September 2025
Â
FP5.VT2D.C.054
Release date: 09 September 2025
Changes:
- Fixed an issue that was causing Quickstep to constantly crash.
- Security patch level: 05 August 2025
Â
FP5.VT28.C.042
Release date: 21 July 2025
Changes:
The Fairphone 5 is getting an upgrade to Android 15! This update brings enhanced security and privacy features to protect you and your device, along with some other improvements.
- 🔒 Private Space
Create a separate private space with an additional layer of authentication to keep sensitive apps, like social, dating or banking apps, away from prying eyes. - 🔑 Passkeys integration
Passkeys was first introduced by Google in Android 14 and is now available on Fairphone, including the recent updates as part of Android 15 which supports one-tap sign in. - 🥷 Theft Protection
Theft Protection is a hub for proactive security features and tips that help keep your devices and data more secure by deterring theft and providing quick recovery in the event of a stolen device. - ✨ Small Quality of Life Improvements:
- New 4x5 grid option for home screen
- Option to increase contrast
- Disable sending device name wifi
- Partial Screen Recording
- Interactive control center Bluetooth panel
- App Archiving
- Set your default wallet app
- You can now remove the search bar from your homescreen to get additional space to place icons
- Security patch level: 05 June 2025
Â
FP5.UT2Q.B.125
Release date: 23 June 2025
Android version:Â 14
Security patch level: June 2025
Changes:
- Operator fixes for RTT (Real Time Text).
- Security patch level.
Â
FP5.UT2P.B.122
Release date: 12 May 2025
Security patch level: May 2025
Changes:
- Fixed an issue that was causing Hearing Aids to not connect properly.
- Gemini will be the default assistant on your Fairphone. Instructions are provided how to use it on first boot setup.
- Implementation of Real Time Text (RTT).
Â
FP5.UT2M.B.113
Release date: 7 April 2025
Security patch level: March 2025
Changes:
Â
FP5.UT2L.B.107
Release date: 10 March 2025
Android version: 14
Security patch level: February 2025
Changes:
- Fixed an issue that was causing the finger print and face unlock to not work under certain circumstances.
- Fixed an issue that was causing incorrect apps to open when using the search function.
Â
FP5.UT2K.B.098
Release date: 27 January 2025
Android version: 14
Security patch level: January 2025
Changes:
- Fixed an issue that was causing the display to glow when the screen was black.
- The Remote Lock feature has now been enabled.
- Minor UI updates.
Â
FP5.UT2H.B.088
Release date: 16 December 2024
Android version: 14
Security patch level: November 2024
Changes:
Â
FP5.UT2E.B.078
Release date: 25 November 2024
Android version: 14
Security patch level: October 2024
- Implementation for French Parental Control
- Fixed an issue causing failures connecting to the B2B Zero Touch Portal
- Fixed an issue that was causing the Automatic network selection not to work correctly under certain circumstances.
- Fixed an issue that was causing some user interface components to not scale properly when the text size was changed.
- Fixed an issue that was causing the apps icons to be partially cut off when searching in the app drawer.
Â
FP5.UT2B.B.072
Release date: 14 October 2024
Android version: 14
Security patch level: September 2024
- Fixed an issue that was causing the 'Show Device Controls' on the lockscreen to reappear after a reboot even if disabled.
- Fixed an issue that was causing the boot animation to slow down under certain circumstances.
- Fixed an issue that was causing the accessibility menu to sometimes disappear.
- Fixed an issue that was causing the external speakers' stereo channels not to properly adapt to the device orientation.
- Minor UI changes and translation improvements.
Â
FP5.UT27.B.059
Release date: 27 August 2024
Android version: 14
Security patch level: August 2024
Changes:
- Camera improvements.
Â
FP5.UT20.B.041
Release date: 15 July 2024
Android version: 14
Security patch level: July 2024
Changes:
Introducing Android 14.
For a full list of changes, see our blog post: Android 14 is here.
Â
FP5.TT4H.A.162
Release date: 24 June 2024
Android version: 13
Security patch level: June 2024
Changes:
Â
FP5.TT4D.A.157
Release date: 13 May 2024
Android version: 13
Security patch level: April 2024
Changes:
- An issue that was causing issues with connecting to certain PEAP protected Wi-Fi networks has been solved.
- The adaptive brightness response of the display in low-light conditions has been improved.
Â
FP5.TT4C.A.154
Release date: 15 April 2024
Android version: 13
Security patch level: March 2024
Changes:
- An issue that was causing the microphone not to be accessible to third-party apps has been solved.
- An issue that was causing the icon of the Calendar app not to update correctly and show the current date has been solved.
- An issue that was causing the Settings to become unresponsive upon exiting from Guest mode has been solved.
Â
FP5.TT46.A.144
Release date: 11 March 2024
Android version: 13
Security patch level: February 2024
Changes:
Â
FP5.TT45.A.141
Release date: 5 February 2024
Android version: 13
Security patch level: January 2024
Changes:
- An issue that was causing the phone to reboot when 5G was enabled on certain networks has been resolved.
- An issue that was causing the face recognition not to be correctly disabled when Lockdown Mode was selected has been resolved.
- A color picker for wallpapers on the home-screen has been introduced.
- A Pocket Mode, to protect you from accidental touches when the phone is in your pocket, has been introduced. You can find it in Settings → Display → Pocket Mode.
- Some typos and/or unclear wordings have been fixed or improved.
Â
FP5.TT40.A.131
Release date: 29 December 2023
Android version: 13
Security patch level: December 2023
Changes:
Â
FP5.TT3Y.A.127
Release date: 11 December 2023
Android version: 13
Security patch level: November 2023
Changes:
- An issue that was causing media content to be played in low resolution for certain media streaming services has been fixed.
- An issue that was causing the double-tap-to-wake function to reset its setting after a reboot has been solved.
- Some issues with the home screen functions have been solved.
- An issue causing an SMS not to be sent when using quick-answer has now been fixed.
- An issue that was causing the preview of the just-taken picture in the Camera app not to appear correctly when an SD card was set as primary storage has now been solved.
- An issue that was causing the double-tap-to-wake function not to work correctly when Always On Display was enabled has now been fixed.
- The auto-focus for Portrait mode in certain conditions has been improved.
- It is now possible to control the behavior of the fingerprint-unlocking feature in Settings → Security.
Â
FP5.TT3P.A.112
Release date: 6 November 2023
Android version: 13
Security patch level: October 2023
Changes:
- DC Dimming has been added as an option to the Display settings. When enabled, this feature helps alleviate eye fatigue or headache for those that can see a flickering effect on the display while the brightness level is low.
Â
FP5.TT3L.A.106
Release date: 9 October 2023
Android version: 13
Security patch level: September 2023
Changes:
- Charging modes: We've made the notification and settings clearer to read the difference between Fast and Eco charging modes.
Â
FP5.TT3G.A.094
Release date: 11 September 2023
Android version: 13
Security patch level: August 2023
Changes:
- Improved Camera performance.
- The network compatibility for several carriers has been enhanced.
Â
