How to manually install Android on your Fairphone
If you are unable to update your Fairphone using standard software updates or want to revert to stock Android from an alternative operating system, you can install the software manually.
Manual software installation is an advanced process. If you prefer a standard update, find out how to check and update your software version.
- Charge your phone to at least 80%.
- Create a backup before making any changes. This process permanently erases all data stored on your phone.
- Turn on Developer options:
- Go to Settings > About phone.
- Scroll to the bottom and tap Build number seven times.
- Enter your PIN or password if prompted.
- Turn on USB debugging:
- Go to Settings > System > Developer options.
- Under Debugging, tap USB debugging to turn it on.
- Make sure you have access to a computer and a USB-C certified data cable.
- Remove any SIM cards or microSD cards.
How to choose your installation method
Almost all Fairphone owners need to use Flashing with fastboot. This is the standard manual installation method for all Fairphone models. However, if you are a Fairphone 3 or Fairphone 3+ owner, you have the option of choosing OTA Sideload instead.
Flashing with fastboot (Standard method for all Fairphone models)
- Compatibility: Works on all Fairphone models.
- Data: Always erases all personal data from your phone.
- Flexibility: Works on any software version. Use this method to downgrade software versions or return to official Fairphone OS from a custom operating system.
If you install an operating system with an older security patch level than your previous software, locking the bootloader might brick your phone.
OTA Sideload (Fairphone 3 and Fairphone 3+ only)
- Compatibility: Exclusively available for the Fairphone 3 and Fairphone 3+.
- Data: Does not erase your personal data.
- Limitations: Only works when updating from older to newer software versions. You cannot use this method to downgrade or return to Fairphone OS from a custom operating system.
How to find and download your software package
Select your phone model and installation method below to find the correct software package. We keep the two most recent factory packages for current Android versions, and the final factory package released for older Android versions.
If a download link is not immediately available after a software update release, please check back later.
Fairphone (Gen. 6) and Fairphone (Gen. 6+)
Android 16
[Current] FP6.QREL.16.115.0.20261009120337_WS1R-factory.zip
- Version: FP6.QREL.16.115.0
- Release date: October 30, 2026
- Security patch: October 5, 2026
SHA256 checksum:
cb262dc7a9c27d68528fa43b77c2474b53a1a1740562c9e64e2991ab63c089b1
FP6.QREL.16.111.0.20260831102426_WS1Q-factory.zip
- Version: FP6.QREL.16.111.0
- Release date: September 28, 2026
- Security patch: September 5, 2026
SHA256 checksum:
97308062afef34cb6edaa5ba6ae30cf5aa61650f6915457fae1abc5c0b5eb9cc
Android 15
FP6.QREL.15.178.0.20260204144956_VS22-factory.zip
- Version: FP6.QREL.15.178.0
- Release date: March 5, 2026
- Security patch: February 5, 2026
SHA256 checksum:
85ea44178af4cd0385cce45a8204000665436a70207a9261465ef43846206692
Fairphone 5
Android 15
[Current] FP5-VT34-factory.zip
- Version: FP5.VT34.C.120
- Release date: November 23, 2026
- Security patch: November 5, 2026
SHA256 checksum:
5a2a3952548f401cce740e2106365108eac46d6fee1d0b34e8d23f3862750622
- Version: FP5.VT32.C.116
- Release date: September 21, 2026
SHA256 checksum:
1f31e462b234448bcc90212650039ca0ab4520a7c79801c399db11e565b3519c
Android 14
- Version: FP5.UT2Q.B.125
- Release date: June 23, 2025
- Security patch: June 5, 2025
SHA256 checksum:
ccef09f6ffd48f0d14bf87297af5756d51fe68ec1a5b710af8f7052a3dde6564
Android 13
- Version: FP5.TT4H.A.162
- Release date: June 26, 2024
- Security patch: June 5, 2024
SHA256 checksum:
38f5cded3cceca25cbf7c9d42ad664ec232a9b1446f3ae17053fe97d7110da01
Fairphone 4
Android 15
[Current] FP4.SREL.15.20.1.20261015064008.user-factory.zip
- Version: FP4.QREL.15.20.1
- Release date: November 9, 2026
SHA256 checksum:
6a5b42cfdf950cacf1dc82f9e077f72d501f94afdf84751f33db2bdd8768d06e
FP4.QREL.15.20.0.20260821145807.user-factory.zip
- Version: FP4.QREL.15.20.0
SHA256 checksum:
4db3d8ce2c972d82700077d13b5a7e40325c721a3fe80fd2647d0064d8abf23c
Android 13
- Version: FP4.TP31.C.0143
- Release date: October 3, 2025
- Security patch: September 5, 2025
SHA256 checksum:
7404233c93f281948134d114247a7dc4cd31466a64ea91f71c76df0f1aad6535
Android 12
- Version: FP4.SP2K.B.089
- Release date: October 3, 2023
- Security patch: August 5, 2023
SHA256 checksum:
485df357646fe96561bc6d1e7c2f7db8f9f4760ef1a7336ab4581968a79939a3
Android 11
- Version: FP4.FP4K.A.179
- Release date: February 3, 2023
- Security patch: January 5, 2023
SHA256 checksum:
1f019c4fdd27b6e57086cea11acf4f81f19888efb47869200cb332812b09e510
Android 13
FP3-6.A.040.4-gms-c8a26ca8-user-fastbootimage.zip
- Version: 6.A.040.2
- Release date: June 22, 2026
MD5:
9598247a7afc9d363e40a27cf86e54b7 -
SHA256:
6ccd63f6dce87283357656c38fb69a0f53116f2174cd31569eeb896799047680
Android 11
FP3-8901.4.A.0028.1-gms-6fba2dc6-user-fastbootimage.zip
- Version: 4.A.0028.1
- Release date: February 29, 2024
MD5:
8ae52d36a3082e692fa45ecc4fcbf4af -
SHA256:
acf4a5faaa04d5bd812691450eea9a6cfa04deae44b71824bf59b9d3744de452
Android 10
FP3_legacy_FP3-REL-Q-3.A.0136-.gms-7c69ec7e-user-fastboot-factory.7z
- Version: 8901.3.A.0136
- Release date: March 22, 2022
MD5:
38fc990f243fcd9406d97cdb4564ef85 -
SHA256:
8de015d33e66b29c39fb9f4d4f50baa1a4b0146ccab2f61b196f135c40f96d39
Android 9
Android 9: FP3_legacy_FP3-REL-2.A.0134-20200703.120010-user-fastbootimage-v2.zip
- Version: 8901.2.A.0134
- Release date: July 30, 2020
MD5:
b078dadf03d336bf087a49b6e0b96e0c -
SHA256:
82fd71a60465e4534c1f535056283785aafd7117ed6a0c2c36987a64e6b6492b
OTA Sideload releases
Android 13
Software release Build 040.3 → 040.4 (A13)
File name: FP3-6.A.040.4-gms-c8a26ca8-user-ota-from-6.A.040.3-manual-sideload.zip
MD5: 4e9c4c0542fa21cd3d93d7b27d494679 | SHA256: 94bf8c131b19b45902350f75e2da8210498d1f32ccb7a2d05b72bea8d027e7f8
Software release Build 040.2 → 040.3 (A13)
File name: FP3-6.A.040.3-gms-dfbdce16-user-ota-from-6.A.040.2-manual-sideload.zip
MD5: 3c99314aeb1c9c0bfa394c16e14d658b | SHA256: 5019edd772992c31ad111aedcc56c289b8c84898bb0eac5f25b733630cab6f6c
Software release Build 039.7 → 040.2 (A13)
File name: FP3-6.A.040.2-gms-d33dc62f-user-ota-from-6.A.039.7-manual-sideload.zip
MD5: 31e2c8fdcec5043ee2286d56e093605e | SHA256: 872c2f3600e6f73e538a1f878b2ff54a8d447f17e23f76e89e64a3b4b90e1af7
Software release Build 039.4 → 039.7 (A13)
File name: FP3-6.A.039.7-gms-44ba459b-user-ota-from-6.A.039.4-manual-sideload.zip
MD5: 58e9194256a45e45a49459c377ac288a | SHA256: d42e92ae211d3e4d28f147e82307c2a4a83c99acb78393803289eec5d5d395fb
Software release Build 035.5 → 039.4 (A13)
File name: FP3-6.A.039.4-gms-2f612659-user-ota-from-6.A.035.5-manual-sideload.zip
MD5: 049b46297975106bc5cc9290f7ae07fc | SHA256: 5f9b0c8dc55317bcf72e727428ce78037f8b8c30539fb53481f790467c25cc1d
Software release Build 035.2 → 035.5 (A13)
File name: FP3-6.A.035.5-gms-921df471-user-ota-from-6.A.035.2-manual-sideload.zip
MD5: d2186b50bd9d9ceeeaf85a3c03d624c8 | SHA256: d1e3bc2e0097c44485ea96b1df74a263101aa97c27008e4e2da72177ca3e4e3a
Software release Build 031.8 → 035.2 (A13)
File name: FP3-6.A.035.2-gms-691ff58c-user-ota-from-6.A.031.8-manual-sideload.zip
MD5: d4921eb5d4cba55288c7988af434e9e5 | SHA256: 73d46166700875172bd18024c3f99afecf748ef36445733994bd9efe9c71a64b
Software release Build 031.7 → 031.8 (A13)
File name: FP3-6.A.031.8-gms-b70b9be7-user-ota-from-6.A.031.7-manual-sideload.zip
MD5: f569d86ce711af7fb5051ce62a7403d8 | SHA256: 2105f19d587c9113d0d99a7442f3f1d47b284f1a88ee741e32653f4e2bf45602
Software release Build 031.5 → 031.7 (A13)
File name: FP3-6.A.031.7-gms-f31c7748-user-ota-from-6.A.031.5-manual-sideload.zip
MD5: 2b65c80a55e9e0aeca32a87d77ab204d | SHA256: f9176004a04cbb282b9601de7331e9d7532677950673ea42dc7222e001bfa2aa
Software release Build 031.2 → 031.5 (A13)
File name: FP3-6.A.031.5-gms-fa7632b5-user-ota-from-6.A.031.2-manual-sideload.zip
MD5: 089d79dbc64194c7eb90f1cb995f32df | SHA256: da01722cb6be28333545e76a7a216c2767d3df48523455e61c74f0a47be7ca09
Software release Build 030 → 031.2 (A13)
File name: FP3-6.A.031.2-gms-880ae2f6-user-ota-from-6.A.030.0-manual-sideload.zip
MD5: 9304b973efa67428691d935a373695ee | SHA256: d36e411cf7563d2a39d90db5a475095a6fed5a0360faede2613c5424a4e2adb1
Software release Build 029 → 030 (A13)
File name: FP3-6.A.030.0-gms-d57debf7-user-ota-from-6.A.029.0-manual-sideload.zip
MD5: c79862b17541660cbaa78b184beaefb6 | SHA256: bfd8ec4dedc8e6ea565ca029054095b59a20899c428bf903cc9b4e150738bc62
Software release Build 028 → 029 (A13)
File name: FP3-6.A.029.0-gms-d294663c-user-ota-from-6.A.028.1-manual-sideload.zip
MD5: ef03ca8c94fdb0511dcb6e3cdd37e257 | SHA256: 0467a4ed38b8c7da99454836c3b7f93777817875d62ae8f0658ce896b538fe9f
Android 11
Software release any A11 version → 027 (A11)
File name: FP3-8901.4.A.0027.1-gms-ba81c0e7-user-ota-manual-sideload.zip
MD5: eb030b0b7d71ab835ed3d20f9e8ac706 | SHA256: 8f224d13ef866326df6b742d4900389dacff1a652b31d49928297a9b4580326f
Software release Build 027 → 028 (A11)
File name: FP3-8901.4.A.0028.1-gms-6fba2dc6-user-ota-from-8901.4.A.0027.1-manual-sideload.zip
MD5: aad8b235aac8470b791f20f45502d708 | SHA256: 2a206990c9caa4801809d9a3ca565f9f4b5f1b0d638ecec124dc3fcd1eaf7a46
Software release Build 026 → 027 (A11)
File name: FP3-8901.4.A.0027.1-gms-ba81c0e7-user-ota-from-8901.4.A.0026.1-manual-sideload.zip
MD5: dddf2bbcad615309536b2faae6a0d068 | SHA256: bac88cfebbeaef13dd68c4d43cf17aad30edcfcdb5d073c8380ad1d6b8ec1e71
Software release Build 025 → 026 (A11)
File name: FP3-8901.4.A.0026.1-gms-94cd6c9f-user-ota-from-8901.4.A.0025.0-manual-sideload.zip
MD5: 988958a5f3df7ae5a8dc4fb3d047c4bf | SHA256: a5ddd266ff173425c4002703aa79cdf70f32d7cefe5496a88f347da5be6a212e
How to install the software on your phone
Choose your installation method below for step-by-step instructions.
Option 1: Flashing with fastboot (for all Fairphone models)
- Unlock your Fairphone's bootloader
- Make sure your Fairphone:
- Is in fastboot mode
- Has an unlocked bootloader
- Is connected to your computer with a USB data cable
- On your computer, extract the downloaded software file.
- Open the extracted folder and locate the correct installation file for your operating system:
- File names start with
flash_fp3,flash_fp4, or similar. - For Windows, use the
.batfile. - For macOS, use the
.commandfile. - For Linux, use the
.shfile.
- Double-click the file to open it and start the installation.
If a permission error message appears on your Mac:
- Click OK.
- Go to Apple menu > System Settings.
- Click Privacy & Security.
- Scroll down to the Security section.
- Click Open Anyway.
Resume the installation script.
Option 2: OTA Sideload for Fairphone 3(+)
These steps apply exclusively to the Fairphone 3(+). Do not attempt this process on other models.
- Connect your Fairphone to your computer using a USB data cable.
- Extract the downloaded Fairphone OS archive file and move the extracted folder to your desktop.
- Open a Command Prompt (Windows) or terminal (macOS / Linux):
- On Linux, enter the command
cd ~\Desktop\platform-tools_r34.0.4-windows\platform-toolsand press Enter ↩. - Note: The exact name of the platform tools folder may vary depending on the release version.
- Put your Fairphone in Recovery mode:
- Power off your Fairphone.
- Press and hold the Power and Volume up buttons at the same time.
- When the phone vibrates, release the Power button while continuing to hold Volume up.
- After a few seconds, the Android Recovery screen appears:
- Use the Volume buttons to highlight Apply update from ADB, then press the Power button to select it.
- In the Command Prompt or terminal window, run
./sideload_update.command.
Still need help?
