What is Adaptive Brightness?
  • Region:Europe
  • Updated
Adaptive Brightness is a feature on your mobile phone that automatically adjusts the screen's brightness based on the ambient light conditions. The goal is to provide optimal visibility while conserving battery life.
How does it work?
Your phone uses sensors to detect the surrounding light levels. Based on this information, it adjusts the screen brightness accordingly. When you move from a dark environment to a bright one, the screen brightens to remain visible. Conversely, it dims in low-light conditions to reduce eye strain and save power.
Does it learn my preferences?
Adaptive Brightness also learns from your manual adjustments. When you manually change the brightness, the system records the ambient light level and your preferred brightness setting. Over time, it uses this information to fine-tune its automatic adjustments, better matching your preferences.
Troubleshooting tips
  • Give it time: The learning process takes several adjustments, so be patient as the system adapts to your preferences.
  • Reset if needed: If you're not happy with how Adaptive Brightness is working, you can reset it by turning it off and then back on. This clears the system's memory of your past preferences and allows it to start learning again.
  • Manual override: Remember, you can always manually adjust the brightness if needed, even with Adaptive Brightness enabled.
-IMPORTANT-
In some cases, the automatic adjustments may not be perfect, especially after sudden changes in lighting. This is because the system needs some time to "learn" the new environment and your preferred brightness level.
