What accessories are available for The Fairphone (Gen. 6)?
With The Fairphone (Gen. 6), we are taking our signature modular design beyond repair, introducing a new line of exclusive accessories that perfectly combine function and form.
Mix and match to find a unique combination to make your Fairphone truly yours!
Lanyard accessory for The Fairphone (Gen. 6)
The Lanyard for the Fairphone (Gen. 6) lets you show off your device to the world, while keeping it handy always. It’s perfect for people who don’t like to keep their phones in their pockets or bags.
The textile cord attaches via a stainless steel and aluminum connection system that is screwed directly and securely to the Fairphone’s lower back-cover. This means you can easily combine it with other accessories like the finger loop and the card holder.
It also works perfectly, with or without a protective case.
A Torx 5 screwdriver is sent with each new Lanyard accessory to install it.
Finger Loop accessory for The Fairphone (Gen. 6)
Keep it flat when you don’t need it. Extend it when you do.
The Finger Loop for The Fairphone (Gen. 6) makes sure you hold on to your Fairphone tight, no matter where you are.
It is perfect for scrolling through your social feeds, watching your shows, or catching up on some reading when you’re on the go.
Made from recycled hard plastic and (non-recycled) silicone, the Finger Loop is easy on the eyes, and easier on your fingers. The accessory integrates into your phone’s design, replacing the lower back cover.
Unscrew the lower back cover with your Torx T5 screwdriver and screw the finger loop into your device instead, keeping it super secure with almost no extra weight.
It works perfectly with the lanyard and a protective case on, and with three color options to choose from, you can customize your Fairphone by mixing and matching colors.
A Torx 5 screwdriver is sent with each new Finger Loop accessory to install it.
Card Holder accessory for The Fairphone (Gen. 6)
The new Fairphone (Gen. 6) Card Holder means you can leave your wallet at home, fitting up to three cards that you can pull out quickly with the easy eject mechanism.
With the back made from recycled hard plastic and the sides and holder itself made from soft plastic and silicone, it’s sturdy yet sustainable, couture yet comfortable.
The integrated modular design means it’s part of your Fairphone, adding minimal bulk to your device.
It works as a replacement lower back cover; all you have to do to get going is unscrew your existing lower back cover, and screw the cardholder in its place.
If you’d like to add a protective cover or the lanyard, you can do that as well.
Available in three colors, it gives you the opportunity to customize your device with a unique color combination that’s truly yours!
A Torx 5 screwdriver is sent with each new Card Holder accessory to install it.
To see how to install the Card Holder accessory, follow our video here:
The Protective Case for The Fairphone (Gen. 6)
Up your Fairphone’s safety and style with one simple accessory. Pick up one of these custom cases that’s designed to give your Fairphone (Gen. 6) all round protection.
With raised bumpers around the cut-out for the iconic Fairphone camera triangle, you know your lenses are going to stay that much more protected.
With recycled hard plastic on the back and soft plastic on the sides, the protective case is built strong and super comfortable to the touch.
Choose between three color options to match your device or to mix it up. It’s totally up to you. The protective case is also compatible with all the other accessories available for the Fairphone (Gen. 6).
Because you shouldn’t have to compromise on customizing your Fairphone just the way you like it.
Note: A screwdriver is not needed to install the Protective Case accessory.
The Fairphone (Gen. 6) Screen Protector
Defend your display with Xensation technology made by Schott. The Fairphone (Gen. 6) Screen Protector protects your screen from scratches and minor falls. Choose between a Standard screen protector or shield your screen from prying eyes with the Privacy Filter screen protector.
Find out more about how to apply your screen protector.
How to use the screwdriver
With all accessories, we recommend to not going too hard with the screws.
Gently tighten screws until you can feel a slight resistance, then turn an eighth of a turn more. When attaching the lanyard, it will need a quarter turn as the final turn.
Your new accessory will be locked securely in place. Feel free to mix it up and add a dash of color to your Fairphone with different color options for your accessories!
