Choosing and applying your Fairphone screen protector
  • Updated
Screen protectors help your phone screen last as long as possible while matching your daily lifestyle. We design these premium glass protectors to fit your phone perfectly and offer filters tailored to how you use your device.
Fairphone screen protector filter options
Screen protector with regular filter
Available for: The Fairphone (Gen. 6/Gen. 6+).
  • Made with Xensation technology to handle scratches and minor falls easily.
  • Feels completely natural as a near-invisible regular protector.
  • Keeps your display safe and secure, while keeping visuals as natural and true to life as possible.
Screen protector with privacy filter
Available for: The Fairphone (Gen. 6/Gen. 6+), Fairphone 5, and Fairphone 4.
  • Reduces damages to your display glass.
  • Ensures that no one can see what's on your screen but you.
  • Uses a two-way filter that decreases visibility at the right and left angles of the screen.
  • Provides 56° of vision: at a 28° angle it has decreased visibility, and at a 45° angle the visibility is fully filtered.
  • Maintains nearly unaffected visibility within those 56°, showing only a very light grey tint.
Screen protector with blue light filter
Available for: Fairphone 5 and Fairphone 4.
  • Filters out blue light to protect your eyes from strain.
  • Lessens the influence of display usage on your sleep while maintaining your screen's true colors.
To ensure a smooth, bubble-free application, make sure you use a clean, quiet, and completely dust-free work surface.
Screen protectors are highly durable once applied, but they can only be used once. Take your time during installation to properly align the adhesive side.
How to apply your Fairphone screen protector
Follow the instructions in the video tutorial or use the step-by-step text guide below:
  1. Switch off your phone and remove its protective case.
  2. Use the cleaning tissue to remove any smudges or grease from your screen.
  3. Use the microfiber screen wipe to clear away watermarks and thoroughly clean the display.
  4. Use the dust removal sticker across the glass to ensure the screen is completely dust-free.
  5. Remove the protective plastic backing layer from the screen protector to expose its active adhesive side.
    Depending on your model, the materials feel slightly different during installation:
    • The Fairphone (Gen. 6/Gen. 6+): The protective layer is flexible, and the screen protector glass is more rigid.
    • Fairphone 5: The screen protector glass is cut slightly smaller than its plastic backing layer.
    • Fairphone 4 & Fairphone 3(+): The plastic backing layer is rigid, and the screen protector glass is more flexible.
  6. With the adhesive side facing down, carefully line up the screen protector with the bottom edge of the screen.
  7. Slowly roll the screen protector flat against the screen, moving from the bottom edge up toward the top.
  8. Let go of the protector to allow it to fully adhere to the screen glass.
  9. Gently apply outward pressure with the microfiber screen wipe to push out any remaining air bubbles.
  10. Turn your phone back on, place it back into its protective case, and you are good to go!
Technical specifications of Fairphone screen protectors
Our premium screen protectors are engineered using Sodium Aluminosilicate Glass paired with a smooth acrylic adhesive layer.
Product dimensions
 Fairphone 5Fairphone 4Fairphone 3(+)
Length157mm155mm151.9mm
Width71.23mm70mm67.3mm
Thickness0.33mm1mm0.33mm
Sustainability and extra features
  • Eco-friendly packaging: Both the outer box and inner protective layers are made entirely from paper cardboard and printed using Cradle to Cradle Certified TM inks.
  • Included in the box: One tailored screen protector and a full installation kit containing a wet cleaning tissue and a microfiber screen wipe.
  • Advanced protection: Features a surface hardness tested to a 9H rating, built-in scratch resistance, and an oleophobic coating that repels fingerprints and makes cleaning easy. The smooth curved glass edges seamlessly blend with your display.
