What accessibility features does Fairphone support?
To learn about accessibility on Android devices, like a Fairphone, you can start on the Android Accessibility Help website or directly jump to a specific guide on the following list:
- How do I get started with Android Accessibility?
- How do I use a screen reader with TalkBack?
- How do I change my display with Android Accessibility?
- What are the interaction controls with Android Accessibility?
- How do I use a braille display?
- How do I use Pixel's Magnifier?
- How do I add captions preferences to my phone?
- How do I use Android Accessibility audio support?
- How do I explore Android accessibility apps & services?
- How do I contact the Google Disability support team?
- How do I update Android accessibility apps?
- How do I turn on TalkBack?
- How do I turn off TalkBack?
Setting up a Murena /e/OS device? Find more details about the accessibility features for this different software here.
Does The Fairphone (Gen. 6/Gen. 6+) support ASHA (direct streaming to hearing aids)?
Yes. The Fairphone (Gen. 6/Gen. 6+) supports the ASHA protocol.
Still need help?
If you still require assistance, reach out to our customer support team. You can also open a support request directly through the My Fairphone app pre-installed on your device.
Â
