How to replace my Fairbuds Earbud Batteries?
Are your Fairbuds not holding a charge like they used to? Don't rush to replace them just yet! One of the key features of Fairphone products is their commitment to repairability, and your Fairbuds are no exception. This article will guide you through the simple steps of replacing the batteries in your Fairbuds earbuds, helping you extend their lifespan and continue enjoying your music sustainably.
-IMPORTANT- Before starting any repairs, ensure the Fairbuds are not charging or connected to any devices via cable. Work on a flat, stable surface. Properly dispose of old batteries by recycling them locally.
Steps to Replace Fairbuds Earbud Batteries
  1. Removing the Silicone Ring
    Use your nails or a prying tool to carefully remove the silicone ring
    Pull up and over the outer earbud, avoiding over-stretching the ring
  2. Opening the Battery Tray
    Locate the +/- indicators to find the rotating battery tray
    Gently open the tray (it does not open completely)
  3. Swapping Batteries
    Remove the old battery
    Insert the new battery in the tray ensuring correct +/- polarity alignment
    Keep batteries and hands clean for optimal connection
  4. Reassembling
    Close the battery tray until it clicks shut
    Replace the silicone ring, aligning the raised outer lip correctly
