How to replace your Fairbuds earbud batteries
  • Updated
If your Fairbuds are no longer holding a charge, replacing the batteries is a quick and simple way to restore performance. With spare parts from our online shop, you can easily extend the lifespan of your audio gear and keep enjoying your music sustainably.
How to replace your earbud batteries
Before starting any repair, ensure your Fairbuds are not charging and are disconnected from any cable. Dispose of old batteries responsibly by recycling them locally.
  1. Remove the silicone ring: Carefully lift the silicone ring using your fingernails or a prying tool. Pull it up and over the outer earbud, taking care not to overstretch the ring.
  2. Open the battery tray: Locate the + and - indicators on the earbud to find the rotating battery tray. Gently rotate the tray open (note that it does not open completely).
  3. Swap the batteries: Remove the old battery. Insert the new battery into the tray, ensuring the + and - polarity signs align correctly with the indicators on the earbud.
  4. Reassemble your earbud: Close the battery tray gently until it clicks shut. Slide the silicone ring back over the earbud, ensuring the raised outer lip aligns properly.
Still need help?
