Transfer data from an iPhone to your Fairphone
  • Updated
Moving your data from an iPhone to a Fairphone requires specific steps to ensure your photos, messages, and apps transfer correctly.
ⓘ These steps require Android 13 or later. Find out How to check and update your software version.
Gather these items before starting your transfer:
  • Both phones: Have your old iPhone and your new Fairphone fully charged and on hand.
  • A stable WiFi connection: Connect your iPhone to a reliable WiFi network.
  • Your Google Account details: If you want to download matching apps from the Google Play Store and sync cloud items like calendar events and contacts.
  • A compatible cable (recommended): Use a cable to connect both phones directly:
    • iPhone 15 and newer: A USB-C to USB-C cable.
    • iPhone 14 and older: A USB-C to Lightning cable, or a USB-A to Lightning cable with a USB-A to USB-C adapter.
How to transfer data using a cable
A direct cable connection moves the widest range of data securely, including your SMS/iMessage history and WhatsApp chats.
  1. Turn on your new Fairphone and tap Start.
  2. Connect to a network by inserting a SIM card, tapping Download a new eSIM, or selecting your WiFi network name.
  3. When prompted to copy apps and data, select the option to set up your phone with an iPhone or iPad.
  4. Sign in to your Google Account.
  5. Follow the on-screen instructions until the phone asks you to connect a cable.
  6. Insert the cable into your old iPhone, tap Next on your Fairphone, and insert the other end into your Fairphone.
  7. Unlock your old iPhone and tap Trust (or confirm the connection) if prompted.
  8. Select the apps and data you want to transfer. If you select WhatsApp, scan the on-screen QR code with your iPhone and follow the extra prompts.
  9. Wait for the transfer to finish until the completion screen confirms your data is ready.
  10. Turn off iMessage and FaceTime on your old iPhone so future messages and calls arrive on your Fairphone:
    • Open Settings > Apps > Messages and switch iMessage off.
    • Open Settings > Apps > FaceTime and switch FaceTime off.
How to transfer data without a cable
If you do not have a compatible cable, you can transfer your core data wirelessly. Download the Android Switch app from the App Store on your iPhone before you begin.
Copying your data without a cable takes longer and transfers fewer data types than the cable method.
  2. Connect to a network by inserting a SIM card, tapping Download a new eSIM, or connecting to WiFi.
  3. When prompted to copy apps and data, tap Next until the phone asks you to find a cable.
  4. Tap No cable > Copy without cable > Switching from iPhone or iPad.
  5. Open the Android Switch app on your iPhone, scan the QR code displayed on your Fairphone, and follow the on-screen prompts.
Manual cloud sync options
If you prefer to move your media and account data manually, or if your photos are stored in iCloud rather than locally on your iPhone, use these methods:
  • Photos and videos: Download the Google Photos app on your iPhone, sign in, and turn on Backup. If you use iCloud Photos with Optimize iPhone Storage turned on, request a direct transfer from iCloud to Google Photos at privacy.apple.com.
  • Contacts and calendar: Add your Google Account on your iPhone under Settings > Apps > Contacts > Contacts Accounts and Settings > Apps > Calendar > Calendar Accounts to sync items already saved to Google. To move items stored only in iCloud, export them from iCloud.com on a computer and import them into Google Contacts and Google Calendar.
What does not transfer automatically
Some services and app data require manual setup on your new Fairphone:
  • The iMessage service: Your past message history transfers when you use a cable, but Apple's iMessage app does not run on Android. Turning off iMessage and FaceTime on your old iPhone ensures new texts arrive as standard messages.
  • Paid apps and App Store subscriptions: Free apps with an Android version download automatically from the Google Play Store. Paid iOS apps do not transfer and must be purchased again on Android. Manage or resubscribe to Apple-billed subscriptions directly with each service provider.
  • App-specific data and logins: WhatsApp chat history transfers via cable, but internal data and login sessions for third-party apps, such as local game saves, banking apps, or two-factor authentication tokens, do not. You must sign in and set these apps up again on your Fairphone.
Still need help?
