How to download and manage apps on your Fairphone
  • Region:Europe
  • Updated
Your Fairphone running Android gives you access to thousands of applications to personalize your phone. Managing your apps is quick and straightforward.
These steps require Android 13 or later. Find out How to check and update your software version.
How to download an app
  1. On your phone, swipe up from the Home screen to see All Apps.
  2. Tap Play Store to open it.
  3. Search for the app you want to download. Look at the star ratings and number of downloads to check if the app is reliable.
  4. Tap the app:
    • For free apps, tap Install.
    • For paid apps, tap the price button.
How to remove or disable an app
  2. Tap and hold the app icon you want to remove.
  3. Tap App info > Uninstall.
Frequently asked questions about apps on Fairphone
Can my Fairphone run my medical device app?
To ensure your safety and the reliable operation of your medical equipment, we recommend contacting your medical device manufacturer directly to verify app compatibility.
Still need help?
If you still require assistance, reach out to our customer support team. You can also open a support request directly through the My Fairphone app pre-installed on your device.
