Android 15: Frequently asked questions (FAQ)
  • Updated
This article answers common questions about Android 15. We cover how to get the latest software, the benefits of updating, troubleshooting steps if you haven't yet received it, and important compatibility details.
How do I get Android 15 on my Fairphone?
Android 15 is available for the Fairphone 4 and later. To install the update, please see our support article: How to check and update your software version.
Why should I update to the latest software version?
We always recommend updating to the latest software version. Beyond new features that enhance your experience, Android 15 contains important security and privacy-focused improvements that help keep your Fairphone safe.
Should I back up my data before installing Android 15?
Yes, we strongly recommend backing up your data before making any significant changes to your Fairphone, like installing a new Android version. To back up your data, please see our support article: How to back up or restore my data.
I haven't received the Android 15 update. What now?
It can take some time for Android 15 to roll out to everyone. If you haven't received the notification yet, check again in a few days. You can also try manually checking for the update by going to Settings → System → System update and tapping Check for update.
I'm having trouble updating to Android 15. What now?
If your Fairphone won't update to the latest software version, you can often fix it in just a few simple steps. Find out how: My Fairphone won't update to the latest software version.
Does the Android 15 update for Fairphone 5 include Always-on Display (AOD)?
The Android 15 update for Fairphone 5 does not reintroduce the Always-on Display (AOD) feature.
Will Android 15 come to the Fairphone 3?
Upgrading the Fairphone 3(+) to Android 15 won't be possible. Similar to Android 14, introducing a newer Android version to the Fairphone 3(+) presents significant challenges due to the device's legacy Linux kernel (4.9). This kernel currently offers limited support for Android 13 and wouldn't support Android 15 at all. For more details regarding Fairphone 3(+) software support and security, please refer to the Fairphone 3(+) FAQ.
