Troubleshoot 4G Calling (VoLTE) and voice call issues
  • Updated
If your mobile internet works on 4G but your voice calls fail, your network operator may not have enabled Voice over LTE (VoLTE) for your account. Follow these diagnostic checks to find the cause and work with your network operator to restore your calls.
Why voice calls stop working
The majority of 3G networks have been shut down over recent years. Because of this change, your Fairphone relies on VoLTE (also known as 4G Calling) to make and receive voice calls.
Your Fairphone supports VoLTE, but some network operators only enable this feature for specific approved smartphones. Even when your phone has the right hardware, your calls will fail if your network operator blocks or disables VoLTE on your SIM card.
Check your phone settings and connection
Complete these four checks in order and write down your results. You will need these exact details when you speak with your network operator.
1. Update your software
Make sure that your phone is up-to-date. If you are not running the latest software, or you are not sure, learn how to check and update your software version.
2. Test mobile data vs. voice calls
The clearest sign of a VoLTE issue is when your mobile data works normally, but voice calls fail to connect.
  1. Turn Wi-Fi off on your phone and confirm that the 4G or LTE icon appears at the top of your screen.
  2. Open a web browser or stream a short video to confirm your mobile data works.
  3. Place a test phone call (you can call an automated service or a friend).
  4. Watch the signal icon at the top of your screen during the call to see if the icon stays on 4G or LTE, or if the icon drops to E, H, or G.
Write down your results:
  • Did your mobile data work while your voice call failed?
  • Did your signal icon stay on 4G or LTE, or drop to E, H, or G?
3. Check your 4G Calling settings
Verify that your network settings allow 4G Calling.
  1. Open Settings > Network and internet > SIMs.
  2. Tap your active SIM card / network operator.
  3. Tap Preferred network type and select 4G/LTE/3G Auto (or the option that includes 4G/LTE).
  4. Look for the 4G Calling or VoLTE toggle:
    • If the toggle is off: Tap the toggle to turn 4G Calling on, then place a test call.
    • If the toggle is missing or greyed out: Your network operator has not enabled VoLTE for your phone. Continue to the next check.
  • Is the 4G Calling or VoLTE toggle visible, and is the toggle turned on, turned off, or greyed out?
4. Check your IMS service status
Use your phone dialer to check the technical connection status between your Fairphone and your network operator.
  1. Open the Phone app.
  2. Dial *#*#4636#*#*.
  3. Tap Phone information (if a menu does not open automatically, tap the three dots menu in the top-right corner and tap IMS service status).
  4. Check the status listed next to IMS Registration and Voice over LTE.
  • IMS Registration: Registered, Not Registered, or Unknown
  • Voice over LTE: Available or Unavailable
Work with your network operator
Once you have your diagnostic results, check our compatibility list and contact your network operator.
1. Check if your network operator is supported
Fairphone officially supports VoLTE and Wi-Fi Calling with a specific list of network operators. Check the supported network operator list to see how to proceed.
If your network operator... Your next action
Is on the supported list VoLTE should work on your phone. Contact your network operator so they can fix the account or SIM provisioning issue.
Is not on the supported list VoLTE may still work if your network operator allows it. Contact your network operator to ask them to enable VoLTE for your phone.
2. Contact your network operator
Contact your network operator's customer support and share the diagnostic details you collected. You can read or send them this message:
"My phone cannot make or receive voice calls after the 3G network shutdown. My phone diagnostics show IMS Registration: [status from check 4] and Voice over LTE: [status from check 4]. Can you help provision or troubleshoot VoLTE on my account?"
Ask your network operator these four questions to get clear answers:
  • Has the 3G network been shut down in my area?
  • Is VoLTE required to make voice calls on your network?
  • Do you officially support VoLTE on Fairphone smartphones?
  • Can you refresh or re-provision my SIM card for VoLTE and IMS services?
  • What answer did your network operator give you?
3. Test with a SIM card from a supported network operator
If your calls still fail, testing another SIM card confirms whether the issue comes from your current network operator or your phone hardware.
  1. Borrow an active SIM card from a friend or family member who uses a provider on our supported network operator list.
  2. Insert the borrowed SIM card into your Fairphone and confirm that 4G Calling is turned on.
  3. Place a test phone call.
  • Were you able to test your phone with a supported SIM card?
  • Did voice calls work with that SIM card?
Next steps based on your results
If your network operator is not supported
If your phone makes calls with a borrowed SIM card, your Fairphone hardware works properly. Your current network operator is blocking VoLTE because they have not approved your Fairphone model on their network.
You have two options to restore voice calls:
  • Switch to a supported network operator (recommended): Move your mobile plan to a provider on our supported network operator list for reliable 4G Calling.
  • Request support from your current network operator: Ask them to add your Fairphone model to their approved VoLTE device list or manually enable VoLTE on your SIM card.
When to contact Fairphone support
Contact Fairphone Customer Support only if you meet all three of these conditions:
  1. Your network operator is on our supported network operator list.
  2. You completed all checks above and recorded the results.
  3. Your network operator confirmed that your account and SIM card are properly set up for VoLTE, yet your voice calls still fail.
When you submit your support request, include all the diagnostic results you wrote down so our team can investigate right away.
Still need help?
