FP3(+). Fairphone OS release notes
Fairphone OS releases for Fairphone 3/Fairphone 3+ (FP3/FP3+), available for the open market.
Here you will also find the updated list of new features, bug fixes, and security patches of each release. The date and availability of system updates may vary by network carriers or country.
To take advantage of the latest improvements and security fixes, make sure to always Update your FP3/FP3+ to the latest software.
Fairphone OS version 8901.4.A.0010/0011 (Android 11) - May 10, 2022
New features
- April 2022 security patch level from the Android Security Bulletin - April 2022
- OS upgrade to Android™ 11
The staged roll out starts today. When available, you’ll receive a push notification to automatically update.
Two different software versions will cover different audiences, although there is no difference in terms of features or quality of the software.
Fairphone OS version 8901.3.A.0136 (Android 10) - March 22, 2022
New features
- March 2022 security patch level from the Android Security Bulletin - March 2022
Fairphone OS version 8901.3.A.0135.20211222 (Android 10) - February 4, 2022
New features
- January 2022 security patch level from the Android Security Bulletin - January 2022
- Update of MyFairphone app from v1.3.0 to v2.1.1.
Fairphone OS version 8901.3.A.0134.202116 (Android 10) - November 26, 2021
New features
- Addressed CVE-2021-1048 security vulnerability.
- The network compatibility for several carriers has been enhanced.
Fairphone OS version 8901.3.A.0132.2021027 (Android 10) - November 16, 2021
New features
- Fixed an issue that was causing, under certain conditions, the incoming caller ID to appear as “unknown”.
- Fixed an issue that was causing, under certain conditions, the brightness level to go to zero when set to Automatic.
- November 2021 security patch level from the Android Security Bulletin - November 2021
Fairphone OS version 8901.3.A.0129.20210805 (Android 10) - August 27, 2021
New features
- August 2021 security patch level from the Android Security Bulletin - August 2021
Fairphone OS version 8901.3.A.0107.20210513 (Android 10) - May 28, 2021
New features
- June 2021 security patch level from the Android Security Bulletin - June 2021
Fairphone OS version 8901.3.A.0101.20210420 (Android 10) - April 28, 2021
New features
- Fixed a sensitivity issue with the microphone/speaker
- Fixed the yellow/blue tint issue while taking pictures
- Fixed other minor issues
- March 2021 security patch level from the Android Security Bulletin - March 2021
Fairphone OS version 8901.3.A.0084.20200204 (Android 10) - March 3, 2021
New features
- Fixed a bug that was causing the microphone/speaker to stop working under certain conditions
- February 2021 security patch level
Fairphone OS version 8901.3.A.0077.20201221 (Android 10) - January 11, 2021
New features
- Usage stability improvements
- December 2020 security patch level
Fairphone OS version 8901.3.A.0066.20201119 (Android 10) - December 8, 2020
New features
- November 2020 security patch level
Fairphone OS version 8901.3.A.0054.20200929 (Android 10) - October 19, 2020
New features
- October 2020 security patch level
Fairphone OS version 8901.3.A.0045.20200905 (Android 10) - September 15, 2020
New features
- August 2020 security patch level
Fairphone OS version 8901.3.A.0033.20200815 (Android 10) - September 7, 2020
New features
- A10 Update
- A10 driver for new Fairphone 3 Camera Module + (48MP)
- A10 driver for new Fairphone 3 Top Module + (16 MP)
- July 2020 security patch level
The software version for FP3/FP3+ (A10) launch.
Only Fairphone 3
This is the full list of previous Fairphone OS releases for the Fairphone 3, available for the open market. Each version has its own release notes. Here you can find the bug fixes and security patches of each release.
Fairphone OS version 8901.2.A.0134.20200703 (Android 9) - 30 July 2020
New features
- June 2020 security patch level
Fairphone OS version 8901.2.A.0120.20200421 (Android 9) - 11 May 2020
New features
- April 2020 security patch level
Fairphone OS version 8901.2.A.0118.20200406 (Android 9) - 24 April 2020
New features
- Notification LED is now available
- Minor fixes for various carriers configurations
Fairphone OS version 8901.2.A.0111.20200131 (Android 9) - 19 March 2020
New features
- Fix for Google Pay issue
- Removal of Search Engine non-dismissable notification
- Stability fix when using dual SIM
- Separation of Pro/Auto mode settings in camera app
- February 2020 security patch level
Fairphone OS version 8901.2.A.0110.20200109 (Android 9) - 29 January 2020
New features
- Wi-Fi compatibility improved
- Fixes for several camera issues
- A new format for RAW captures (DNG)
- January 2020 security patch level
Fairphone OS version 8901.2.A.0105.20191217 (Android 9) - 28 December 2019
New features
- HDR improvements
- December 2019 security patch level
Fairphone OS version 8901.2.A.0101.20191115 (Android 9) - 15 November 2019
New features
- GMS package updated Oct'19
- October 2019 security patch level
Fairphone OS version 8901.2.A.0096.20191002 (Android 9) - 22 October 2019
New features
- Camera user experience improvement - time-lapse and slow-motion improvements
- Google Services package update Sep'19
- September 2019 security patch level
Fairphone OS version 8901.2.A.0081-20190816 (Android 9) - 27 August 2019
SW version Fairphone 3 launch.
