How to use Fairbuds touch controls for audio, calls, and Active Noise Canceling
  • Region:Europe
  • Updated
Your Fairbuds feature touch controls on both earbuds so you can manage playback, phone calls, and sound modes without touching your phone. Here is how to use every gesture to control your audio experience.
How to control audio playback
Use simple taps and swipes on either earbud to manage your music and podcasts:
  • Single tap (left or right earbud): Play or pause audio.
  • Double tap (right earbud): Skip to the next track.
  • Double tap (left earbud): Skip to the previous track.
  • Swipe up (left or right earbud): Increase volume.
  • Swipe down (left or right earbud): Decrease volume.
How to manage phone calls
Handle incoming phone calls directly through your earbuds:
  • Double tap (either earbud): Answer or end a call.
  • Tap and hold for two seconds (either earbud): Reject an incoming call.
How to switch Active Noise Canceling modes
Toggle between listening modes to control how much background sound you hear:
  • Tap and hold for two seconds (either earbud): Cycle between Active Noise Canceling, Transparency Mode, and ANC Off.
You can customize touch control gestures and adjust noise cancellation intensity through the official Fairbuds app on your phone.
