How to turn on and charge your Fairbuds
Keeping your Fairbuds charged ensures uninterrupted listening throughout your day. Here is how to turn your earbuds on or off and charge them safely using standard USB-C equipment.
How to power your Fairbuds on and off
Your earbuds power on and off automatically based on their position in the charging case:
  • Turn on: Open the charging case lid and remove the earbuds. They will turn on and connect to your last paired device automatically.
  • Turn off: Place both earbuds back into the charging case and close the lid.
How to charge your Fairbuds and charging case
  1. Place both earbuds into the charging case and close the lid.
  2. Connect a USB-C cable to the port on the bottom of the charging case.
  3. Plug the other end of the cable into a certified power adapter supplying 5V and at least 0.5A.
  4. Check the LED light on the front of the case to view current battery status:
    • Green: Fully charged
    • Yellow: Medium battery level
    • Red: Low battery level
Charging times and battery specifications
  • Earbuds charge time: Approximately two hours inside the case to reach 100% battery capacity. Charging your earbuds for 10 minutes inside the case provides up to 90 minutes of playback time.
  • Charging case charge time: Approximately two hours via USB-C cable.
