How to replace the battery and speaker cover on Fairbuds XL
  • Updated
If your Fairbuds XL battery is holding less charge or you need to access the inner earcup cavity, replacing the battery or speaker cover is straightforward. This guide walks you through safely swapping these components on your headphones.
  • A clean, flat work surface
  • A plastic card or guitar pick for leverage
  • Your replacement battery or left speaker cover from our online shop
Safely dispose of your old battery at a nearby electronic waste recycling center or municipal collection station. Do not throw it in regular household waste.
How to replace your battery and speaker cover
  1. Turn off your Fairbuds XL and keep your replacement spare parts nearby.
  2. Locate the left earcup where the battery is housed.
  3. Insert your fingers or a plastic prying card under the edge of the left speaker cover and lift it away from the earcup.
  4. Lift the battery out of the cavity. Hold onto it tightly so you do not drop it.
  5. Place your replacement battery into the earcup using the correct orientation for your model:
    • Fairbuds XL (2023): Insert the battery with "yours to open, yours to keep" facing upward.
    • Fairbuds XL (2025): Insert the battery with "fairphone" and the battery icon facing upward.
  6. Press down gently on the battery to ensure it fits securely in place.
  7. Align the left speaker cover over the earcup and press down gently from top to bottom until it snaps into place.
Still need help?
