How to replace the headband, cover, and cable (Fairbuds XL 2023)
If you need to replace the fold-open headband cover, internal audio cable, or headband frame on your 2023 model Fairbuds XL, follow these step-by-step instructions.
These instructions are for the Fairbuds XL (2023 Model). See the instructions for the Fairbuds XL (2025 Model).Â
- A clean, flat work surface
- A Phillips #00 screwdriver
- Replacement 2023 headband, fold-open cover, or audio cable spare parts from our online shop
How to remove the fold-open headband cover
- Turn off your Fairbuds XL.
- Unplug the internal USB-C cable from the speaker unit on one side.
- Flap open the headband cover.
- Lift the silver locking lever to release the headband base and speaker.
- Slide the headband cover completely off the headband frame.
How to remove the headband frame and audio cable
- Unplug the internal USB-C cable on the opposite earcup.
- Lift the silver locking lever on the opposite side to release that headband base and speaker unit.
- Slide the original internal USB-C cable out of the headband frame.
How to assemble your replacement parts
- Slide the replacement internal USB-C cable back into the channel of the headband frame.
- Slide the fold-open headband cover over the cable and headband frame.
- Slide the headband base into the headband frame and push the silver lever down to lock it.
- Flap the headband cover closed over the frame.
- Apply the speaker cover.
- Plug the internal USB-C audio cable firmly into the sockets on both speaker units. Ensure both ends are fully seated to maintain a reliable audio connection.
Still need help?
