What to do if Fairphone Moments does not show when flipping the switch
  • Updated
If flipping the physical switch on your phone does not launch Fairphone Moments or redirects you to the Google Play Store, we can help you fix it. Follow these step-by-step troubleshooting instructions to restore normal function.
What to check first
  • Confirm that your device is The Fairphone (Gen. 6/Gen. 6+) running Android for Fairphone.
  • Open Settings on your phone and verify that Fairphone Moments is selected as the action assigned to the physical switch.
How to resolve Google Play Store redirects
If flipping the switch redirects you to the Google Play Store instead of launching Fairphone Moments:
  1. Open Settings > System Updates and ensure your device software is completely up to date.
  2. Open the Google Play Store, confirm you are signed in to your Google account, and check for pending updates for Google Play Services and Fairphone Moments.
  3. Install all available updates, restart your phone, and flip the switch again.
How to reset Fairphone Moments storage
If the physical switch is assigned correctly but Fairphone Moments still fails to open, clear the app storage to reset your preferences.
Clearing storage will remove any custom moments or profile rules you previously created.
  1. Go to Settings > Apps.
  2. Tap See all apps and select Fairphone Moments.
  3. Tap Storage & cache, then tap Clear storage.
  4. Tap Delete in the confirmation prompt.
  5. Exit Settings and flip the physical switch down again.
How to check your app versions
Fairphone Moments relies on two separate applications installed on your phone. To check if you have the latest software versions installed:
  • Fairphone Moments main app: Go to Settings > Apps and tap Fairphone Moments.
  • Switch Button Settings system app: Go to Settings > Apps > See all apps. Enable search in system apps, then search for Switch Button Settings.
Still need help?
If you still require assistance, reach out to our customer support team. You can also open a support request directly through the My Fairphone app pre-installed on your device.
