Camera features and specifications for The Fairphone (Gen. 6/Gen. 6+)
  • Updated
Learn about the upgraded camera system on your Fairphone (Gen. 6/Gen. 6+). This guide details key features, lens functions, photo modes, and full technical specifications.
Devices covered in this guide
  • The Fairphone (Gen. 6)
  • The Fairphone (Gen. 6+)
Camera quality and key improvements
The Fairphone (Gen. 6/Gen. 6+) introduces several hardware and software upgrades to help you take clearer photos:
  • Main camera: Features a Sony LYTIA sensor to capture detailed images across different lighting conditions.
  • Ultra-wide camera: Uses an enhanced sensor to capture wide landscapes and group shots with greater clarity.
  • Front camera: Includes a high-quality Samsung sensor with autofocus to keep your selfies sharp.
  • System performance: A powerful chipset works together with refined software tuning to deliver higher overall photo quality.
Understanding the rear camera lenses
You will see three lens openings on the back of the phone, but only two of these openings contain traditional camera lenses.
The main camera and ultra-wide camera sit behind two of the openings.
The third opening houses a Time-of-flight (TOF) sensor. This sensor measures distance and helps the camera system focus accurately.
How to take 50MP full-resolution photos
By default, the camera combines individual pixels (pixel binning) to balance image detail and file size. To disable pixel binning and capture photos using the full 50MP resolution:
  1. Open the Fairphone Camera app on your phone.
  2. Swipe through the mode menu and tap High pixel.
  3. Tap the shutter button to capture your photo.
High-resolution photos create larger files and use more storage space on your device.
Video recording options and limits
The Fairphone (Gen. 6/Gen. 6+) supports rear video recording up to 4K resolution at 30 frames per second (30fps). Due to hardware processing limits, recording in 4K at 60fps is not supported.
Complete camera technical specifications
Camera Technical specifications Video recording options
Main camera
  • 50MP Sony LYTIA 700C (IMX896)
  • 1/1.56-inch sensor
  • 1.0µm pixel size
  • f/1.88 aperture
  • 84.4° field of view
  • Optical Image Stabilization (OIS) and Electronic Image Stabilization (EIS)
  • 4K UHD @ 30fps
  • 1080p FHD @ 30/60fps
  • 720p HD @ 30fps
Ultra-wide camera
  • 13MP (OV13B10)
  • 1/3.06-inch sensor
  • 1.12µm pixel size
  • f/2.2 aperture
  • 108° field of view
  • Electronic Image Stabilization (EIS)
Shared with main camera video options
Front camera (Selfie)
  • 32MP (KD1 sensor)
  • 1/3.44-inch sensor
  • 0.64µm pixel size
  • f/2.0 aperture
  • 81.8° field of view
  • 0.75x–1x digital zoom
  • Autofocus
  • 2K QHD @ 30fps
  • 720p HD @ 30fps
Still need help?
If you still require assistance, reach out to our customer support team. You can also open a support request directly through the My Fairphone app pre-installed on your device.
