How to use Fairbuds 2 touch controls for audio, calls, and Active Noise Canceling
Your Fairbuds 2 feature touch controls on both earbuds so you can manage playback, phone calls, and sound modes without touching your phone. Here is how to use every gesture to control your audio experience.
How to control audio playback
Use simple taps and swipes on either earbud to manage your music and podcasts:
- Single tap (left or right earbud): Play or pause audio.
- Double tap (right earbud): Skip to the next track.
- Double tap (left earbud): Skip to the previous track.
- Long press (left earbud): Increase volume.
- Long press (right earbud): Decrease volume.
Tip: Removing either or both Fairbuds from your ears automatically pauses playback.
How to manage phone calls
Handle incoming phone calls directly through your Fairbuds 2:
- Single tap (either earbud): Answer a call.
- Double tap (either earbud): Hang up.
- Long press (either earbud): Reject a call.
How to switch Active Noise Canceling modes
Toggle between listening modes to control how much background sound you hear:
- Tap three times (either earbud): Cycle between Active Noise Canceling, Transparency Mode, and ANC Off.
You can customize touch control gestures and adjust noise cancellation intensity through the official Fairbuds app on your phone.
Still need help?
If you still require assistance, reach out to our customer support team. You can also open a support request directly through the My Fairphone app pre-installed on your device.
