Technical specifications for the Fairbuds 2
  • Updated
To review the audio performance, physical dimensions, battery endurance, or sustainability specifications of your earbuds, this guide provides the complete technical specifications for the Fairbuds 2.
General design and controls
  • Headphone type: TWS earbuds
  • Earbud dimensions: 30.2x22.6x24.38mm
  • Charging case dimensions: 56.5x45.2x27.7mm
  • Color choices: Horizon Black, Forest Green
  • Weight: 5.8g (earbuds), 64g (with case)
  • Ingress protection: IP54 (earbuds only)
  • Control type: Capacitive touch
Sound and acoustic performance
  • Driver diameter: 11mm
  • Driver type: Bio-Cellulose Dynamic
  • Frequency response: 20Hz - 20kHz
  • Sensitivity: 99±2dB at 1kHz
  • Driver impedance: 32Ω
Noise canceling and microphone features
  • Active noise canceling: Yes (Hybrid ANC)
  • Transparency mode: Yes
  • Environmental Noise Cancellation (ENC): Yes, three-mic array (per side)
  • Microphones: Total of six microphones (three per earbud)
Battery life and charging
  • Earbud battery life: Calling and music time up to eight hours (ANC off) and six hours (ANC on)
  • Total playtime with case: Up to 40 hours
  • Charging time: Two hours (case and earbuds); a 10-minute quick charge provides two hours of playtime
  • Battery capacity: 45mAh (earbuds), 500mAh (case)
  • Wireless charging: No
Connectivity and audio features
  • Bluetooth version: Version 6.0
  • Multi-point connectivity: Dual connection
  • Bluetooth range: 10m (line of sight)
  • Codecs: AAC, SBC, LC3, LDAC
  • Bluetooth profiles: A2DP V1.3.2, AVRCP V1.6.2, GAVPD V1.3, HFP V1.7.2, HSP V1.2
  • Ports: USB-C
  • Cable compatibility: USB Type-C (USB 2.0 / 3.0 / 3.2; cable not included)
  • Smart assistants: Not built-in
  • Auto-off feature: Yes, powers off automatically after 15 minutes of inactivity
Sustainability and materials
  • Fair and recycled materials: 48.6% by total weight*
  • PFAS-free: 100% PFAS-free exterior, safe for skin*
  • Recycled plastics: 73% recycled plastics of total plastic content*
  • Metals and fair-mined materials:
    • 100% recycled rare earth elements in speaker magnets*
    • 100% recycled tin in solder paste*
    • 100% fair gold (via Fairmined credits and Responsible Gold credits)
    • 100% fair cobalt in the battery (via Fair Cobalt credits)
    • 100% fair-mined copper (via credits)
    • 100% fair silver (via Fairmined credits)
  • Longevity: Modular and repairable design
  • Fair working conditions: Living wage bonus and worker voice program
  • Climate conscious assembly: Yes, 100% renewable energy used during assembly
  • E-waste neutrality: 100% e-waste neutral
  • Certifications: LONGTIME® certified*
Frequently asked questions
Are the Fairbuds 2 PFAS-free?
We pioneered the use of PFAS-free and more than 70% post-consumer recycled plastics—keeping persistent chemicals off your skin and choosing smarter materials for the planet.
Is production carbon neutral or renewable-energy powered?
The production of the Fairbuds 2 uses 100% renewable energy.
What does e-waste neutral actually mean?
For every Fairbuds 2 unit sold, Fairphone collects and recycles an equivalent weight of e-waste elsewhere, offsetting the product's own eventual waste footprint.
Does not using glue impact the water resistance of the Fairbuds 2?
No. Water resistance is maintained through other sealing methods rather than glued-in batteries.
Are the Fairbuds 2 water- and dust- resistant?
The Fairbuds 2 earbuds are sweat-, splash-, and dust-resistant, but are not fully waterproof or dustproof. They carry an IP54 rating, meaning they are built to handle everyday weather and workouts without requiring permanent adhesives that would block repairs. If your Fairbuds 2 get wet, wipe them down thoroughly with a soft, dry, lint-free cloth and let them air dry completely before placing them back into the case.
Still need help?
If you still require assistance, reach out to our customer support team. You can also open a support request directly through the My Fairphone app pre-installed on your device.
