How to factory reset Fairbuds 2
Resetting your Fairbuds 2 restores default connection settings to fix audio drops or Bluetooth pairing issues.
A factory reset will erase all saved settings, including paired devices, ANC mode preferences, and Fairbuds app configurations (such as custom audio tuning).
How to reset your Fairbuds 2
- Open the Bluetooth menu on your connected device and tap Forget or Unpair next to Fairbuds 2.
- Place both earbuds inside the charging case with the lid open.
- Press and hold the function button on the charging case for 10 seconds.
- The LED lights inside the case will flash quickly five times to confirm the factory reset is complete.
Still need help?
