How to replace the outer shell and core on your Fairbuds 2 charging case
Replacing the outer shell or charging case core of your Fairbuds is a simple way to keep your earbuds protected and working like new.
- A T5 Torx screwdriver
- Your Fairbuds charging case
- A replacement outer shell or charging case core
Step 1: Empty the charging case
- Open the lid of your charging case.
- Remove both earbuds and set them safely aside.
- Close the lid and turn the charging case over.
Step 2: Remove the bottom screw
- Locate the single screw on the bottom of the charging case.
- Using your T5 Torx screwdriver, turn counterclockwise to unscrew it.
- Keep the screw in a safe spot for reassembly.
Step 3: Separate the outer shell and core
- Open the lid of the charging case.
- Place your fingers inside the charging case core.
- Gently pull apart with your other hand to separate the outer shell from the core.
- Swap in your new outer shell or core as needed.
Step 4: Reassemble the charging case
- Align the notches on the outer shell and core, then slide them together until they snap firmly into place.
- Insert the screw into the bottom and turn clockwise to tighten it without overtightening.
- Return your earbuds to the charging case.
Still need help?
