Technical specifications for Fairbuds XL
This guide provides the complete technical specifications for both the Fairbuds XL (2025) and the original Fairbuds XL (2023).
Applies to these models
- Fairbuds XL (2025)
- Fairbuds XL (2023)
Key differences between the Fairbuds XL (2023) and Fairbuds XL (2025)
| Feature | Fairbuds XL (2023) | Fairbuds XL (2025) |
| Speaker drivers | 40mm dynamic drivers | 40mm dynamic drivers with stronger N52 magnets and paper-based membrane |
| Audio tuning & EQ | Standard tuning and app presets | Neutral sound profile with updated app presets and customizable EQ |
| Impedance & sensitivity | 32Ω, 99±2dB at 1kHz | 40Ω, 107dB at 1kHz (0.2Vrms) |
| Ear cushions | 100% vegan leather (PU) | Bird's eye mesh fabric |
| Headband | 100% vegan leather (PU) | Water-resistant net fabric |
| Weight | 330g | 324g |
| Charging time | Up to 3 hours | Less than 2 hours |
| Automatic power-off | Not available | Powers off automatically after a period of inactivity |
Physical design and materials
- Headphone type: Over-ear, closed-back (circumaural)
- Form factor: Foldable, modular design with user-replaceable spare parts
- Dimensions (unfolded): 190mm x 180mm x 70mm
- Dimensions (folded): 140mm x 180mm x 70mm
- Weight: 324g (Fairbuds XL 2025), 330g (Fairbuds XL 2023)
- Water and dust protection: IP54 rating (Splash-proof: protected against dust, sweat, and light rain)
- Color choices: Horizon Black, Forest Green (2025); Black, Green (2023)
Materials:
- Fairbuds XL (2025): Bird's eye mesh fabric ear cushions, water-resistant net fabric headband
- Fairbuds XL (2023): 100% vegan leather on ear cushions and headband
- Shared sustainable materials: 100% recycled aluminum, 100% recycled tin in solder paste, more than 80% recycled plastics, 100% Fairtrade gold in the supply chain, and a travel pouch made from recycled fabrics
Audio and noise cancellation
Driver size and type: 40mm dynamic drivers
- Fairbuds XL (2025): Upgraded with stronger N52 magnets and a paper-based membrane for improved bass and mid/high frequency accuracy, tuned for a flatter, more neutral sound profile
- Frequency response: 20Hz–20kHz
- Impedance: 40Ω (Fairbuds XL 2025), 32Ω (Fairbuds XL 2023)
- Sensitivity: 107dB at 1kHz (0.2Vrms) (Fairbuds XL 2025), 99±2dB at 1kHz (Fairbuds XL 2023)
- Noise control: Digital Hybrid Active Noise Cancellation (ANC) and Transparency mode (Ambient Sound mode)
- Microphones: 6 microphones total (2 on the left earcup, 4 on the right earcup)
Connectivity and controls
- Wireless connection: Bluetooth 5.1 with dual multi-point connection
- Bluetooth range: Up to 10m (line of sight)
- Supported Bluetooth profiles: A2DP V1.3.2, AVRCP V1.6.2, GAVDP V1.3, HFP V1.7.2, HSP V1.2
- Supported audio codecs: AAC, SBC, aptX HD
- Ports and wired audio: USB-C port (supports charging, digital audio, and analog audio via a USB-C to 3.5mm adapter cable, sold separately)
- On-device controls: Multifunction joystick (volume, play/pause, skip/previous, power/pairing) and dedicated ANC button
- Smart assistants: Compatible with Google Assistant, Apple Siri, and Amazon Alexa
- Companion app: Fairbuds app with EQ presets and customizable EQ settings
Battery and power
- Battery type and capacity: 800mAh user-replaceable Lithium-ion (Li-ion) battery
- Battery longevity: Retains over 80% nominal capacity after more than 500 charge cycles
Playback and call time (at 80% volume):
- ANC off: Up to 30 hours
- ANC on: Up to 26.5 hours
- Standby time: Up to 320 hours
- Charging time: Less than 2 hours (Fairbuds XL 2025), less than 3 hours (Fairbuds XL 2023)
- Wireless charging: Not supported
- Power management: Automatic power-off after inactivity (Fairbuds XL 2025 only)
Frequently asked questions
Do the Fairbuds XL have dual port connectivity?
Ye, you can connect up to two devices simultaneously via Bluetooth.
Are the Fairbuds XL water- and dust- resistant?
The Fairbuds XL are splash- and dust-resistant, but not waterproof or dustproof. They carry an IP54 rating, allowing them to withstand everyday weather and light workouts while remaining modular and easy to repair without glued-in seals. If your Fairbuds XL get wet, unplug any connected USB-C cable and wipe down the outer ear cups, headband, and buttons with a soft, dry, lint-free cloth.
Still need help?
If you still require assistance, reach out to our customer support team. You can also open a support request directly through the My Fairphone app pre-installed on your device.
