How to perform a factory reset on your Fairbuds XL
You can perform a factory reset on your Fairbuds XL to clear previous Bluetooth connections and restore your headphones to their default settings.
Performing a factory reset erases all saved Bluetooth pairings from your headphones.
Perform a factory reset
- Open the Bluetooth settings on any previously paired phone, tablet, or computer and select Forget or Unpair for your Fairbuds XL.
- Push and hold the joystick to the right for five seconds.
- Wait until you hear the voice prompt say "Factory reset complete".
- Press and hold the ANC button for three seconds to put your Fairbuds XL into pairing mode so you can connect them to a new device.
Still need help?
