Update your Fairbuds 2 or Fairbuds XL firmware
You can check for and install firmware updates for your Fairbuds 2 or Fairbuds XL directly through the Fairbuds app on your smartphone.
- A compatible audio product: Fairbuds 2 or Fairbuds XL.
- A charged battery: Make sure both your smartphone and Fairbuds or Fairbuds XL are charged before starting the update.
- The Fairbuds app: The official Fairbuds app on your smartphone
How to check for and install an update
- Connect your Fairbuds 2 or Fairbuds XL to your smartphone via Bluetooth.
- Open the Fairbuds app on your smartphone.
- Connect your Fairbuds 2 or Fairbuds XL to the app if prompted.
- Tap the hamburger menu (three lines) in the top-right corner of the screen.
- Select Update. The app will display your current firmware version and let you know if a new update is available.
- If a new firmware version is available, tap Start update and follow the on-screen prompts until the installation finishes.
Keep the Fairbuds app open on your screen and do not disconnect your Fairbuds 2 or Fairbuds XL until the update is complete.
Still need help?
