Android 17 software update: Features and frequently asked questions
  • Updated
This guide answers common questions about the Android 17 update on your Fairphone. Learn how to update your software, explore new features, and resolve common software questions.
Currently supported devices
  • The Fairphone (Gen. 6): Staged release from November 30, 2026
  • The Fairphone (Gen. 6+): Staged release from November 30, 2026
Roadmapped devices
  • Fairphone 5: First half of 2027
What to do before you update
We strongly recommend you create a backup of your personal data before installing Android 17 on your Fairphone. Creating a backup protects your photos, contacts, and app data during software updates. Learn how to back up or restore your data.
How to install Android 17
The Android 17 update rolls out gradually to device owners. If you have not received a notification yet, you can manually check for the update:
  1. Go to Settings > System > System update.
  2. Tap Check for update.
  3. If no update appears, check again in a few days. For more detailed instructions on software updates, see how to check and update your software version.
What's new in Android 17
Updating your software keeps the Fairphone safe with security improvements and new features. Android 17 remains bloatware-free, keeping your phone clean without unwanted pre-installed apps.
Performance and battery improvements
  • Faster app launches: Improved memory handling speeds up app launch times by up to 38%, keeping multitasking responsive.
  • Longer standby time: Smarter idle power management reduces background battery drain for up to 17% longer standby time.
  • Smoother graphics and faster browsing: Enjoy up to 17% higher frame rates in demanding games and nearly 7% faster web page loading.
Multitasking and family features
  • App Bubbles: Minimize apps into compact, floating windows for quick, one-tap switching while multitasking.
  • Native parental controls: Manage system-level Family Link features and set screen time limits directly on the device using a local Parent PIN.
Security and protection advancements
  • Theft Protection Lock: Use AI, motion sensors, Wi-Fi, and Bluetooth to recognize sudden snatch-and-run movements (such as someone grabbing your phone and running, biking, or driving away) and automatically lock your screen to protect your data.
  • App Lock: Add an extra layer of privacy by locking individual apps behind your device credentials.
  • Temporary Location Access: Grant apps one-time, temporary access to your location instead of ongoing permissions.
Note: Some metrics were verified by internal laboratory testing under specific conditions.
Frequently asked questions
Release timeline and rollout
Why don’t you release new software on the same day as Google?
Every new Android version has to be adapted to our specific hardware, tested thoroughly together with our chipset partner, and certified before it can reach our users. We do that carefully because a stable update matters more to us than a fast one. Android 17 arrives on the Fairphone (Gen. 6) and Fairphone (Gen. 6+) just six months after Google’s release, making it the fastest rollout of a new Android version in Fairphone’s history.
Why have I not received Android 17 on my Fairphone (Gen. 6) or Fairphone (Gen. 6+) yet?
Devices receive the update in waves during the weeks following launch, so some users get it earlier than others. You don’t need to do anything; your phone will notify you as soon as the update is ready for your device.
Why do I need to wait to receive Android 17 on my Fairphone (Gen. 6) or Fairphone (Gen. 6+)?
A staged rollout releases the update in waves, starting with a smaller group of devices and expanding step by step. This approach lets us monitor the rollout closely and catch any potential issues before they reach everyone, making it the most responsible way to deliver a major update to a phone you rely on every day.
Features and Fairphone apps
What are App Bubbles?
App Bubbles let you minimize an app into a compact, floating window that docks at the side of your screen, so you can switch back to it with one tap. This makes multitasking between apps — like a chat and a map — much smoother.
How do the new parental controls work? Do I need a second device?
No, you don't need a second device. The parental controls are built directly into the system and don’t require a remote setup from a parent’s phone. You can set screen time limits right on the device using a local Parent PIN.
Will Fairphone Moments and the physical switch still work on Android 17?
Yes, both Fairphone Moments and the physical switch carry over to Android 17 and continue to work as expected.
Will the Fairphone Gallery app still work on Android 17?
Yes, the Fairphone Gallery app remains pre-installed on the Fairphone (Gen. 6) and Fairphone (Gen. 6+) and works seamlessly on Android 17.
Performance, data, and support
Will Android 17 affect my battery life?
Yes, in a positive way: Android 17 brings up to 17% longer standby time on the Fairphone (Gen. 6) and Fairphone (Gen. 6+) thanks to smarter idle power management. As with any major update, your phone may use slightly more battery for the first day or two while it optimizes apps in the background, which is completely normal and settles on its own.
Will I lose my data when I update?
Your personal data remains safe during the update, though occasionally some apps may need to be reinstalled manually afterward.
Can I roll back to Android 16 if I don’t like Android 17?
Going back to an earlier Android version isn’t supported through a regular update. We also don’t recommend rolling back, as newer versions include the latest security protections to keep your phone safe.
Are there any known issues with the update?
No, there are currently no known issues with the Android 17 update.
Does Android 17 change how long the Gen. 6 and 6+ are supported?
Our commitment stays the same: software support for the Fairphone (Gen. 6) and Fairphone (Gen. 6+) until 2033, alongside a five-year warranty. Android 17 is part of delivering on that long-term promise.
Why did my navigation bar layout reverse when I updated?
If your navigation bar layout is now inverted, it's an easy fix:
  1. On your Fairphone, go to Settings then tap System
  2. Tap Gestures, then Navigation mode, then tap the cog next to 3-button navigation
  3. Toggle “Swap Back/Recents Navigation” on or off
Still need help?
If you still require assistance, reach out to our customer support team. You can also open a support request directly through the My Fairphone app pre-installed on your device.
