Fairphone 4 Release Notes
  • Region:Europe
  • Updated
Find the release notes for current and previous software versions.
Current software version
FP4.QREL.15.20.1
Release date: 02 November 2026
Android version: 15
Security patch level: October 2026
Changes:
  • Security patch level.
Previous software versions
FP4.QREL.15.20.0
Release date: 28 September 2026
Android version: 15
Security patch level: September 2026
Changes:
Resolved Issues
  • Fixed an issue where VoLTE and Wifi Calling icons were being shown simultaneously in the status bar
Other improvements
  • Slide bars have been added to control the level of vibration in the Vibrations & haptics menu.
FP4.QREL.15.19.2
Release date: 03 August 2026
Android version: 15
Security patch level: August 2026
Changes:
FP4.QREL.15.19.1
Release date: 06 July 2026
Android version: 15
Security patch level: June 2026
Changes:
  • Mobile Network Usability improvements.
FP4.QREL.15.17.2
Release date: 01 June 2026
Android version: 15
Security patch level: May 2026
Changes:
  • Optimized background process management for smoother multitasking.
  • Fixed an issue where speaker did not work after reboot or software update.
  • Simplified the bootloader unlock process. See the support pages for details on How to unlock the bootloader. Shoutout to Yannic Ambach for the expert catch on our host certificate validation. We appreciate the extra set of eyes!
FP4.QREL.15.16.1
Release date: 30 March 2026
Android version: 15
Security patch level: March 2026
Changes:
  • Fixed an issue where the device would no boot on Android 15.
  • Fixed an issue that was causing the launcher (Quickstep) to often crash.
  • Fixed an issue that resulted in the Dynamic app icons not displaying the correct information for date and time.
  • Fixed an issue that resulted in the device randomly rebooting.
  • Fixed an issue where VoLTE was not available while roaming.
  • Fixed an issue where there was a NFC error displayed on the home screen.
  • Fixed an issue where the device would not boot on Android 15 if fingerprint sensor is not available.
FP4.SREL.15.14.4
Release date: 06 January 2026
Android version: 15
Security patch level: January 2026
Changes:
FP4.TP32.C.0144
Release date: 24 November 2025
Android version: 13
Security patch level: November 2025
Changes:
FP4.QREL.15.14.3
Release date: 27 October 2025
Android version: 15
Security patch level: October 2025
Changes:
The Fairphone 4 is getting an upgrade to Android 15! This update brings enhanced security and privacy features to protect you and your device, along with some other improvements.
  • 🔒 Private Space
    Create a separate private space with an additional layer of authentication to keep sensitive apps, like social, dating or banking apps, away from prying eyes.
  • 🔑 Passkeys integration
    Passkeys was first introduced by Google in Android 14 and is now available on Fairphone, including the recent updates as part of Android 15 which supports one-tap sign in.
  • 🥷 Theft Protection
    Theft Protection is a hub for proactive security features and tips that help keep your devices and data more secure by deterring theft and providing quick recovery in the event of a stolen device.
  • ✨ Small Quality of Life Improvements
    • Option to increase contrast
    • Disable sending device name wifi
    • Partial Screen Recording
    • Interactive control center Bluetooth panel
    • App Archiving
    • Set your default wallet app
    • Option to remove searchbar from homescreen
Other changes:
FP4.TP33.C.0146 (Orange Belgium/France specific version)
Release date: 05 February 2026
Android version: 13
Security patch level: December 2025
Changes:
FP4.TP32.C.0144 (Orange Belgium/France specific version)
Android version: 13
Changes:
FP4.TP31.C.0143
Release date: 03 October 2025
Android version: 13
Security patch level: September 2025
Changes:
FP4.TP2V.C.0137
Release date: 06 August 2025
Android version: 13
Security patch level: July 2025
Changes:
FP4.TP2U.C.0136
Release date: 12 June 2025
Android version: 13
Security patch level: June 2025
Changes:
FP4.TP2R.C.0132
Release date: 31 March 2025
Android version: 13
Security patch level: March 2025
Changes:
FP4.TP2P.C.0130
Release date: 27 January 2025
Android version: 13
Security patch level: January 2025
Changes:
FP4.TP2N.C.0128
Release date: 25 November 2024
Android version: 13
Security patch level: November 2024
Changes:
FP4.TP2L.C.0126
Release date: 30 September 2024
Android version: 13
Security patch level: September 2024
Changes:
FP4.TP2I.C.0121
Release date: 29 July 2024
Android version: 13
Security patch level: July 2024
Changes:
FP4.TP2G.C.0119
Release date: 03 June 2024
Android version: 13
Security patch level: May 2024
Changes:
  • An issue that was causing the clock on the lock screen not to update correctly has been solved.
  • The wallpaper settings can now also be searched using the search bar in Settings.
FP4.TP2D.C.0112
Release date: 04 April 2024
Android version: 13
Security patch level: March 2024
Changes:
  • An issue that was causing the screen brightness to drop when entering the Camera settings has been solved.
  • An issue that was causing the "Display network name" feature not to work as intended has been solved.
  • An issue that was causing the battery capacity not to show correctly on third-party apps has been solved.
  • An issue that was causing the Settings to be unresponsive when exiting Guest mode has been solved.
FP4.TP29.C.0101
Release date: 19 February 2024
Android version: 13
Security patch level: January 2024
Changes:
  • Capture images faster
    The overall camera experience is much more reactive with faster auto-focus, continuous shooting and smoother zooming. Making moving subjects easier to snapshot even for all lighting conditions.
  • Greater quality in low light
    Capture low-light and night scenes in greater detail with less grainy imagery. Shooting 4K video, HDR photos or using the flash also benefit from sharper colors and better contrasting while a newly tuned AI immediately detects the most optimal settings for each scene.
Other resolved issues:
  • Camera app would sometimes freeze while deleting an image from the preview.
  • Camera Electronic Image Stabilization (EIS) is now performing as expected.
Other improvements:
  • New wallpaper available.
FP4.TP25.C.095
Release date: 16 January 2024
Android version: 13
Security patch level: December 2023
Changes:
  • An issue that was causing the screen to freeze and/or not turn on correctly in certain conditions has been fixed.
  • An issue that was causing the Wi-Fi Calling option to grey out after rejecting a call has been fixed.
  • The option to show the network name on the Status bar has been made available again.
FP4.TP20.C.087
Release date: 25 December 2023
Android version: 13
Security patch level: November 2023
Changes:
  • An issue that was causing the phone to reboot in certain conditions when registered on 5G has been fixed.
  • An issue causing an SMS not to be sent when using quick-answer has now been fixed.
  • Some issues with the homescreen functions have been solved.
FP4.TP1X.C.079
Release date: 03 November 2023
Android version: 13
Security patch level: October 2023
Changes:
  • Adaptive Brightness.
    The brightness level will now be remembered by the device when set.
FP4.TP1V.C.073
Release date: 02 October 2023
Android version: 13
Security patch level: August 2023
Changes:
  • Introducing Android™ 13:
    • Your Fairphone. Your style.
      Customize your phone to your personal style. With themed app icons, you can set apps and more to match your phone’s wallpaper tint and colors. Choose your style in Settings → Wallpaper → Wallpaper & style.
    • New media controls
      Your music has never looked so good. Album artwork will now be on full display and features a dancing playback bar.
    • Language preferences per app
      Assign different language settings to individual apps, so you can move fluidly between languages on your device, just like in real life.
  • Resolved issues
    • Display Brightness: the brightness would sometimes suddenly drop to a very low level.
    • Home Screen: the search bar would sometimes disappear.
  • Other improvements
    • Privacy and security: You have more control over what information apps can and can’t access – including specific photos, videos and clipboard history.
FP4.SP2L.B.095
Release date: 03 October 2023
Android version: 12
Security patch level: September 2023
Changes:
FP4.SP2K.B.089
Release date: 08 September 2023
Android version: 12
Changes:
FP4.SP2J.B.086
Release date: 21 August 2023
Android version: 12
Security patch level: July 2023
Changes:
  • Ghost touches: an issue that causes the user interface to move or jump without touching the screen.
  • Call volume: we've added another step to the phone call volume range so that you can adjust at even lower volumes.
  • Quick Settings: you can now Enable or Disable the microphone and camera by swiping down the menu from the top of the screen.
  • Wi-Fi Hotspot: you can also enable the 5 GHz frequency via the Settings app.
FP4.SP2G.B.079
Release date: 17 July 2023
Android version: 12
Security patch level: June 2023
Changes:
  • Home screen: the search bar in the app drawer remains visible at all times.
  • Display: colors no longer change after turning on the screen of the device.
  • 4G and Wi-Fi Calling: On/Off switch is now available via the Mobile network settings.
  • Bluetooth audio: Qualcomm aptX and aptX Adaptive codecs issues resolved.
FP4.SP29.B.069
Release date: 05 June 2023
Android version: 12
Security patch level: May 2023
Changes:
  • If you use a work profile on your Fairphone, we have removed some unnecessary background applications.
FP4.SP28.B.065
Release date: 8 May 2023
Android version: 12
Security patch level: April 2023
Changes:
  • Further personalize your Fairphone with accent colors. System menus and buttons will automatically change color, depending on your Home Screen wallpaper.
FP4.SP25.B.058
Release date: 07 April 2023
Android version: 12
Security patch level: March 2023
Changes:
  • Improved position of Home and Wallet shortcuts on the Lock Screen.
  • Added one-handed mode. This can be enabled from the Accessibility settings.
  • Added "Screenshot" button to the Recent apps screen.
  • Fixed a bug, which caused 16:9 photos taken by the main camera to be slightly cropped on all sides.
  • Fixed a bug, which caused the battery percentage to be pushed outside the screen border when there were many other icons in the notification bar.
FP4.SP21.B.048
Release date: 03 March 2023
Android version: 12
Security patch level: February 2023
Changes:
  • The automatic minimum brightness has been reduced, following the feedback received from our users.
  • A bug that was causing the Bluetooth audio to stop working when the aptX HD codec was selected has been fixed.
  • Third-party apps are now also able to access and use the wide-angle sensor of the camera module.
FP4.SP1Y.B.041
Release date: 01 February 2023
Android version: 12
Security patch level: December 2022
Changes:
  • Upgrade to Android 12:
    • Conversation Widgets
      An all-new conversation widget puts the conversations with the people you care about front-and-center on your home screen so you never miss a chat from your loved ones. You can even see missed calls, birthdays and more at a glance.
    • Mic & Camera Indicators and Toggles
      With Android 12, you can see when an app is using your microphone or camera thanks to a new indicator in your phone’s status bar. And if you don’t want any apps to access your microphone or camera, you can completely disable those sensors using two new toggles in quick settings. Simply flip the switch.
    • Approximate Location Permissions
      While some apps need precise location information for tasks like turn-by-turn navigation, many other apps only need your approximate location to be helpful. With Android 12, you can choose between giving apps access to your precise location or an approximate location instead.
    • Privacy Dashboard
      The Privacy dashboard gives you a clear and comprehensive view of when apps have accessed your location, camera, or mic over the past 24 hours. If you see anything that you’re not comfortable with, you can manage permissions right from the dashboard.
      …and much more.
  • Added a toggle in the Camera app, which allows the user to save selfies as previewed (mirrored). Disabled by default.
  • Fixed an issue, which was preventing the adjustment of display brightness via the accessibility menu shortcut.
  • The network compatibility for several carriers has been enhanced.
FP4.FP4K.A.179
Release date: 03 February 2023
Android version: 11
Security patch level: January 2023
Changes:
FP4.FP4I.A.175
Release date: 19 December 2022
Android version: 11
Security patch level: November 2022
Changes:
FP4.FP4G.A.170
Release date: 3 October 2022
Android version: 11
Security patch level: September 2022
Changes:
FP4.FP4D.A.163
Release date: 12 September 2022
Android version: 11
Security patch level: August 2022
Changes:
  • The layout of the status bar has been adapted to better fit the display size.
FP4.FP44.A.149
Release date: 08 August 2022
Android version: 11
Security patch level: July 2022
Changes:
  • The camera’s auto-focus and white balance features have been improved.
FP4.FP40.A.142
Release date: 11 July 2022
Android version: 11
Security patch level: June 2022
Changes:
  • Camera tuning update.
FP4.FP3W.A.128
Release date: 30 May 2022
Android version: 11
Security patch level: May 2022
Changes:
  • Added automatic power-off when idle in Fastboot mode for 10 minutes.
  • Improved performance of microphone in Signal app.
  • Improved retention of mobile network settings after update.
FP4.FP3V.A.116
Release date: 25 April 2022
Android version: 11
Security patch level: April 2022
Changes:
  • Improved OIS calibration experience after installing new camera module.
FP4.FP3T.A.107
Release date: 04 April 2022
Android version: 11
Security patch level: March 2022
Changes:
  • Addressed an issue that was causing, under certain conditions, the microphone to record with a lower volume than normal in some third-party apps.
  • Addressed an issue that was causing pictures taken in 48MP mode to be overexposed, in certain conditions.
  • The “TCO Certified” logo has been added to the boot-up screen.
  • Addressed multiple minor issues that were causing, in rare conditions, certain apps/services of the device to crash or to be unresponsive.
FP4.FP3S.A.103
Release date: 04 March 2022
Android version: 11
Security patch level: February 2022
Changes:
  • MyFairphone app updated to version 2.1.5
  • Addressed an issue that was causing an incorrect message to be shown when trying enable OEM unlocking with no internet connection.
  • The default date has been changed to 11/11/2021 during the Setup Wizard (OOBE) when no internet connection is available.
FP4.FP3R.A.099
Release date: 04 February 2022
Android version: 11
Security patch level: December 2021
Changes:
  • Fixed an issue that was causing Google Play system updates to be unavailable.
  • Fixed an issue that was causing errors during SD card formatting and use.
FP4.FP3Q.A.094
Release date: 21 December 2021
Android version: 11
Changes:
FP4.FP3N.A.091
Release date: 29 November 2021
Android version: 11
Security patch level: November 2021
Changes:
  • Added the possibility to hide/show the network name on the status bar when on the main screen.
  • Fixed some incorrect animations during the Setup Wizard.
