FP4. Replace a spare part
The Fairphone 4 is designed to make repair accessible. So, the separate spare parts of the device connect within the modular architecture without glue or complex screws.
Every spare part is easily accessible and replaceable, which is good for the planet as well as your pocket.
The only tool you will need is a Phillips #00 screwdriver to access all spare parts of the Fairphone 4. The screws of the Fairphone 4 are also used for most (sun)glasses, so you might already have this size of crosshead screwdriver at home. If not, we offer an iFixit PH00 screwdriver in our online shop.
Prepare
We made the replacement of each spare part as easy as possible. However, we recommend to prepare a bit before you start, as you still handle vulnerable electronics.
- Do not open your device when not needed. When in doubt, consult the troubleshooter guide to find out if your issue can be solved in another way.
- In case you want to repair something that might be covered by the manufacturing or extended warranty, please contact customer support first before you order a spare part.
- In case you need to replace a part due to water damage or a fall, we recommend to have a professional assess the full scope of the damage first. It might be that more than one part is impacted, so replacement of one part might not solve your issues. As user damage is not covered by the manufacturing warranty, you can use a local repair service of your choice (including our repair center).
- Before you actually start, read the following instructions and watch the accompanying video tutorials.
- Update your device. To make sure you have the right firmware drivers, update your device to the latest software version first. Otherwise, the software can not 'read' the new spare part.
- Charge the battery if possible, so you can test the spare part right after your replacement.
- Use a flat and clean working surface and a good light source.
- Get your Phillips #00 screwdriver ready. Make sure the screwdriver is of a sturdy quality as inferior tools can damage screws.
- Do not use metal tools to disconnect the BTB-connectors. You can use a fingernail or a plastic object such as a spudger, a credit card or a guitar plectrum.
- IMPORTANT -
To prevent damaging your Fairphone 4, please avoid electrostatic discharge (ESD). When opening the Fairphone 4, try to avoid touching the metal components with your bare hands. We recommend using rubber or cotton gloves or to ground yourself.
Open up the Fairphone 4
To access the spare parts, you must follow a specific order. Please follow the instructions below in text or as shown in the relevant videos.
You have to open up the phone first:
- Power off the phone
- Take off the Back cover (see the first steps of our video tutorial)
- Take out the battery.
To replace the display, you only have to unscrew and disconnect the display.
To replace the other spare parts, you sometimes have to remove another spare part or connector first.
Replace the Display
To replace the display of your Fairphone 4, follow the instructions in our video tutorial or in the text below the video.
Open up the phone first:
- Power off the phone.
- Take off the Back cover and take out the battery.
Continue to remove the spare part:
- With your Phillips 00 screwdriver, unscrew the 8 black screws keeping the display in place.
- Separate the display carefully from the mid-frame.
- Disconnect the connector cable from the display at the BTB-connector - indicated by the white triangle.
Then, mount the new display:
- Attach the BTB-connector to the new display.
- Place the new display carefully to the midframe again - make sure the cable stays flat.
- Fasten the display to the phone with the 8 black screws.
- Place back the battery and the Battery cover.
- Power the phone back on to check your new display.
You replaced your display!
Replace the Main Cameras
To replace the rear cameras of your Fairphone 4, follow the instructions in the video tutorial or in the text below the video. The main cameras contain: Wifi, Bluetooth, mobile network and GPS antennas, the rear cameras including the Time-of-Flight (ToF) sensor and the flash.
Continue to take out the Main Cameras unit:
- With your Phillips 00 screwdriver, unscrew the single silver screw of the camera lid - marked with 1 - right above the battery housing.
- Gently lift off the camera lid, starting from the right bottom side.
- Disconnect the visible two BTB-connectors, each marked with a white triangle.
- Now the third BTB-connector is visible, also marked with a white triangle: disconnect that one too.
- Remove the remaining 5 silver screws that hold the Main Cameras unit in place.
- Lift up the Main Camera unit from the bottom right side to take it out - avoid touching the battery pins.
Then, mount the new Main Cameras unit:
- Place the new Main Cameras unit in the phone - insert from the top.
- Screw back the 5 silver screws to hold the Main Cameras unit in place.
- Reconnect the BTB-connector that will be hidden by the other two.
- Reconnect the remaining two BTB-connectors.
- Insert and connect the camera lid from left to right.
- Insert and tighten the remaining silver camera connector screw.
- Power the phone back on to check your new cameras.
You replaced your Main Cameras!
Replace the Earpiece
To replace the secondary speaker of your Fairphone 4, follow the instructions in the video tutorial or in the text below the video. To take out the Earpiece, you will have to remove the Main Cameras unit first. The receiver of the Earpiece is used for calling and is the secondary speaker to provide stereo sound.
- Lift up the Main Camera unit from the bottom right side to take it out. The Earpiece is now visible.
Continue to take out the Earpiece:
- Disconnect the BTB-connector of the Earpiece at the white triangle.
- Take the Earpiece out.
Mount the new Earpiece
- Insert the new Earpiece, top first
- Connect the BTB-connector
Then, mount the Main Cameras unit:
- Insert and tighten the 5 silver screws to hold the Main Cameras unit in place.
- Power the phone back on to check your new Earpiece.
You replaced your Earpiece!
Replace the Selfie Camera
To replace the front camera of your Fairphone 4, follow the instructions in the video tutorial or in the text below the video. To take out the Selfie Camera, you will have to remove the Main Cameras unit first.
- Lift up the Main Camera unit from the bottom right side to take it out. The Selfie Camera is now visible.
Continue to take out the Selfie Camera:
- Disconnect the BTB-connector of the Selfie Camera at the white triangle.
- Take the Selfie Camera out.
Mount the new Selfie Camera
- Insert the new Selfie Camera, top first
Power the phone back on to check your new Selfie Camera.
You replaced your Selfie Camera!
Replace the Loudspeaker
To replace the main speaker of your Fairphone 4, follow the instructions in the video tutorial or in the text below the video. The speaker of the Loudspeaker is used for all audio, except for calls. Together with the Earpiece, it provides stereo sound. It also hosts the vibration motor and some mobile network antennas.
Continue to take out the Loudspeaker:
- With your Phillips 00 screwdriver, unscrew the 6 silver screws of the Loudspeaker.
- With a plastic credit card or plectrum, take out the Loudspeaker. Start at the battery housing side.
Mount the new Loudspeaker
- Insert the new Loudspeaker, bottom first
- Insert and tighten the 6 silver screws to hold the Loudspeaker in place.
- Last steps:
Power the phone back on to check your new Loudspeaker.
You replaced your Loudspeaker!
Replace the USB-C port
To replace the USB-C port of your Fairphone 4, follow the instructions in the video tutorial or in the text below the video. To take out the USB-C port, you will have to remove the Loudspeaker unit first. The USB-C hosts the USB-C port for charging and data- and audio transfers.
- The USB-C port is now visible.
Continue to take out the USB-C port:
- Disconnect the BTB-connector of the USB-C port at the white triangle.
- Take the USB-C port out.
Mount the new USB-C port:
Mount the Loudspeaker:
Last steps:
- Power the phone back on to check your new Loudspeaker.
You replaced your USB-C port!
Frequently Asked Questions (FAQ)
Q: Do you sell the Core part?
A: No, we do not offer the Core part for standalone sale, as it houses both SIM ports and mother- and daughterboard. In case there is a possible issue with one of the components on the Core part, we want to research and solve the issue ourselves. The registration of the SIM slots and their unique IMEI numbers are quite important legally, selling the Core part as a standalone part poses some extra vulnerabilities regarding this identification. Next to that, some components on the Cor part are quite fragile and we want to replace these under controlled circumstances.
Q: Why is the microphone not in the Bottom spare part, like with Fairphone 2 and Fairphone 3?
A: Microphones are very sensitive small components. There are 3 microphones on the Fairphone 4. They have to be positioned in particular places of the device for them to work properly (voice recording, ambient noise, video recording, etcetera). This positioning and their vulnerability limits the possibility to make them modular. This is why these 3 microphones are located on the Core part and not replaceable via one on the other spare parts.
