Fairphone cables and chargers: Technical specifications, power output, and warranty
Learn about the technical specifications, power distribution, and warranty coverage for Fairphone USB-C cables and wall chargers.
Having trouble charging your smartphone? If you have already ruled out damaged or incompatible cables, use our troubleshooting tool to diagnose the issue.
Fairphone offers three USB-C to USB-C cables. Every cable features a black-and-gray braided design, a detachable USB-A to USB-C adapter, and Modular Organizer Stripes.
| Feature | USB 2.0 (100cm) | USB 2.0 (250cm) | USB 3.2 (100cm) |
| Length | 100cm | 250cm | 100cm |
| Diameter | 4.5mm | 4.5mm | 5.5mm |
| Data transfer speed | 480Mbps | 480Mbps | 20Gbps |
| Video transmission | Not supported | Not supported | 4K at 120Hz or 8K at 30Hz |
| Maximum power | 240W (48V, 5A) | 240W (48V, 5A) | 240W (48V, 5A) |
| Charging protocols | PD 3.1, EPR, PPS, QC4+ | PD 3.1, EPR, PPS, QC4+ | PD 3.1, EPR, PPS, QC4+ |
| E-Marker chip | Yes | Yes | Yes |
| VBUS resistance | Less than 0.1mΩ | Less than 0.1mΩ | Less than 0.1mΩ |
Fairphone wall chargers
Fairphone currently sells two EU wall chargers. The 30W charger works well for smartphones and small accessories, while the 65W charger provides enough power for laptops and multiple devices at once.
| Feature | 30W EU charger | 65W EU charger | 30W UK charger (discontinued) |
| Ports | 1 USB-C | 2 USB-C, 1 USB-A | 1 USB-C, 1 USB-A |
| Dimensions (excluding plug) | 32 x 32 x 35mm | 42 x 32 x 58mm | 90 x 28 x 47mm |
| Color | Black | Black | Black |
| Maximum power output | 30W | 65W | 30W |
| Charging protocols | PD 3.0 (5V, 9V, 12V, 15V, 20V), PPS (3.3–11V at 3A, 3.3–16V up to 2A), QC 3.0, Samsung AFC (9V), FCP (5V, 9V, 12V), Apple (5V/2.4A) | PD 3.0, PPS (3.3–21V at 3.0A), DCP (5V/1.5A), BC 1.2, QC 2.0/3.0/4+, AFC, FCP, SCP, Apple, Samsung, MTK PE+ 2.0 | N/A |
| Efficiency | Up to 90% | Up to 90% | Up to 82% |
| Standby power draw | Less than 0.1W | Less than 0.25W | 0.052W |
| Current leakage | Less than 250uA | Less than 250uA | N/A |
| Input voltage | 100–240V (with under- and over-voltage protection) | 100–240V (with under- and over-voltage protection) | 100–240V |
| Safety protections | Output under- and over-voltage, over-current, short circuit, USB weak short circuit | Output under- and over-voltage, over-current, short circuit, USB weak short circuit | N/A |
How the 65W charger distributes power
The 65W charger has two USB-C ports (First and Middle) and one USB-A port. When you connect multiple devices, the First USB-C port always takes priority and delivers up to 45W.
| Number of ports used | Active ports | Power output per port |
| One port | First USB-C only | 65W |
| One port | Middle USB-C only | 65W |
| One port | USB-A only | 30W |
| Two ports | First USB-C and Middle USB-C | First: 45W / Middle: 20W |
| Two ports | First USB-C and USB-A | First: 45W / USB-A: 18W |
| Two ports | Middle USB-C and USB-A | Middle: 7.5W / USB-A: 7.5W (much lower output) |
| Three ports | First USB-C, Middle USB-C, and USB-A | First: 45W / Middle: 7.5W / USB-A: 7.5W |
Warranty coverage
- Purchased on or after May 6, 2025: Your accessory is covered by your country's statutory legal guarantee (minimum two years in the EU) plus an automatic one-year Fairphone extended warranty. You do not need to register your accessory.
- Purchased before May 6, 2025: Your accessory is covered by your standard national legal guarantee only. The discontinued 30W UK charger is also covered by the standard legal guarantee.
Compatibility and sustainability
- Why chargers are not included with Fairphones: Most households already own compatible USB chargers. Leaving chargers out of smartphone boxes reduces electronic waste. If you need new accessories, visit the Fairphone online shop.
- Using third-party chargers: Only use undamaged, compatible equipment to prevent battery degradation or safety hazards. Review our minimum charging requirements before using non-Fairphone chargers.
- Materials and ethical sourcing: Fairphone cables use 100% recycled plastics and 100% recycled copper. Fairphone engineers these cables to exceed industry bend-test standards. Our EU chargers use 98% recycled plastics, 100% recycled copper-zinc alloy, and paper packaging. Factories producing these accessories support living wages and worker-voice programs.
Still need help?
