How to set up hotspot and tethering on your Fairphone
  • Region:Europe
  • Updated
You can use hotspot and tethering to share your Fairphone's mobile data connection with other devices via Wi-Fi, Bluetooth, and USB. This lets connected devices access the internet using your mobile plan.
ⓘ These steps require Android 13 or later. Find out How to check and update your software version.
How to set up a Wi-Fi hotspot
To share your connection over Wi-Fi:
  1. On your Fairphone, go to Settings > Network & internet > Hotspot & tethering.
  2. Tap Wi-Fi hotspot and then tap Use Wi-Fi hotspot to toggle it on or off.
How to set up Bluetooth tethering
To share your connection using Bluetooth:
  1. Connect your Fairphone with the other device using Bluetooth.
  2. On your Fairphone, go to Settings > Network & internet > Hotspot & tethering.
  3. Tap Bluetooth tethering to toggle it on or off.
How to set up USB tethering
To share your connection using a physical cable:
  1. Connect your Fairphone to the other device using a USB cable.
  3. Tap USB tethering to toggle it on or off.
Still having trouble?
If your connection is not working as expected, you can usually resolve it with a few simple checks. Read our article on how to troubleshoot a hotspot connection for step-by-step guidance.
Still need help?
