Use 4G Calling on your Fairphone (after 2G and 3G network shutdowns)
  • Updated
To keep making voice calls on your Fairphone in areas without 2G or 3G coverage, use 4G Calling (also known as Voice over LTE, or VoLTE).
ⓘ These steps require Android 13 or later. Find out How to check and update your software version.
Supported Fairphone models
Your smartphone supports 4G Calling if you own a Fairphone 3 or a newer model.
How to stay connected
Follow these three steps to keep your Fairphone working properly after a 2G or 3G network shutdown:
1. Use a supported network operator
The most reliable way to keep a stable connection is to use a SIM card from a network operator that Fairphone has officially tested.
Select your phone model below to view the list of compatible network operators:
Fairphone (Gen. 6/Gen. 6+)
Compatible network operators for The Fairphone (Gen. 6/Gen. 6+):
  • Austria: A1, Magenta, Telekom
  • Belgium: Orange, Proximus
  • Denmark: 3
  • Finland: Elisa
  • France: Bouygues Telecom, Orange, SFR
  • Germany: 1&1, O2, Telekom, Vodafone
  • Netherlands: KPN, Odido, Vodafone
  • Norway: Ice, Telenor, Telia
  • Luxembourg: Post
  • Sweden: Tele2, Telenor, Telia, Three
  • Switzerland: Salt, Sunrise, Swisscom
  • United Kingdom: EE, Honest, Sky, Vodafone, Your Co-op
Fairphone 5
Compatible network operators for the Fairphone 5:
  • Austria: A1, Drei, Magenta, Telekom
  • Belgium: Orange, Proximus, Telenet
  • Czechia: Telekom
  • Denmark: 3
  • Finland: Elisa
  • Norway: Nuuday, Telenor, Telia
  • Luxembourg: Post, Tango
  • Poland: Telekom
  • United Kingdom: EE, Honest, O2, Sky, Vodafone, Your Co-op
Fairphone 4
Compatible network operators for the Fairphone 4:
  • Austria: A1, Telekom
  • Czechia: Telekom
  • Denmark: 3, TDC NET
  • Finland: Elisa
  • France: Bouygues Telecom, Free, Orange, SFR
  • Germany: O2, Germany, Vodafone
  • Hungary: Telekom
  • Norway: Telenor, Telia
  • Spain: Orange
  • United Kingdom: EE, Sky, Vodafone
Fairphone 3(+)
Compatible network operators for the Fairphone 3(+):
Note: 4G Calling is only supported for SIM1 on the Fairphone 3 and Fairphone 3+.
  • Denmark: 3
  • Finland: Elisa
  • Germany: O2, Vodafone
  • Ireland: Vodafone
  • Italy: Vodafone
  • Netherlands: KPN, Vodafone
  • Luxembourg: Post
  • Portugal: NOS
  • Spain: Orange, Vodafone
  • Sweden: 3
  • United Kingdom: Sky, Vodafone
2. Turn on 4G Calling in your settings
You can turn on 4G Calling directly on your smartphone:
  1. Open the Settings app on your Fairphone.
  2. Tap Network & internet > SIMs.
  3. Tap the SIM card you want to configure.
  4. Toggle 4G Calling on.
These menu options may have a different name or stay hidden depending on your network operator.
Dual SIM and 4G Calling: All Fairphones support Dual SIM, Dual Standby (DSDS). If you use two supported SIM cards with 4G Calling enabled, both SIM cards stay active and ready to receive calls in standby mode, even if 2G and 3G networks have shut down. You can only use one SIM card at a time for an active call — while one SIM card is in use, the other remains in standby.
3. Keep your software updated
Make sure that your phone is up-to-date. If you are not running the latest software, or you are not sure, learn how to check and update your software version.
Install software updates as soon as they become available. Software updates contain important network configuration settings that help your Fairphone communicate with your network operator.
What to do if your network operator is not on the list
If your network operator is not listed as officially supported, 4G Calling might still work, though Fairphone cannot guarantee a stable or consistent connection. If you experience call issues:
  • Contact your network operator: Ask your operator to manually provision your SIM card for VoLTE, or request that your operator adds Fairphone to their list of supported devices.
  • Switch to a supported operator: If your current operator cannot support 4G Calling on your Fairphone, switch to a network operator from our officially tested list.
Find out how to troubleshoot 4G Calling.
Future network operator support
Fairphone continuously tests network configurations to ensure reliable call quality and connection stability. We update the list of compatible operators regularly as new tests are completed, so check back on this page for the latest compatibility updates in your area.
Still need help?
