Set up near field communication (NFC)
  • Region: Europe
  • Updated
NFC allows your Fairphone to communicate wirelessly with nearby devices. When in close proximity to an NFC-enabled device, you can share data, make contactless payments, and more.
These steps require Android 13 or later. If you are not sure which version your Fairphone is running, see How to check and update your software version.
How to turn NFC on or off
To turn NFC on or off using the Settings app:
  1. On your Fairphone, go to Settings → Connected devices → Connection preferences → NFC.
  2. Tap Use NFC to toggle on or off.
To turn NFC on or off using Quick Settings:
  1. On your Fairphone, swipe down twice from the top of your screen to open all Quick Settings.
  2. Tap NFC to turn on or off.
Tip: If you don't see the NFC tile in your Quick Settings, find out how to add it: Find and change settings quickly.
How to set up contactless payments with NFC
To set up contactless payments with NFC, you'll need a payment app that supports contactless payments, like Google Wallet.
Once you have an app that supports contactless payments, you can set it as your default payment app. To set your default payment app:
  2. Tap Contactless payments and select a payment app to set it as the default.
To make a payment using the default payment app, hold the back of your Fairphone to a payment terminal.
Need more help?
If NFC or contactless payments aren't working, you can often fix it in just a few simple steps. Find out how: Troubleshoot the NFC.
