Maximize Battery Lifespan
The Fairphones, like most modern smartphones, come with a lithium-ion battery. However, unlike most modern smartphones, your Fairphone has a removable battery!
The capacity of your Fairphone's battery should be more than enough to last you through the day:
- The Fairphone 4 battery holds a typical capacity of 3905 mAh.
- The Fairphone 3(+) battery holds a typical capacity of 3060 mAh.
- The Fairphone 2 battery holds a typical capacity of 2420 mAh.
Regardless of how big a battery is, some apps and settings may drain the battery faster. Below, you'll find some tips for extending your battery life.
General
Update you phone
Make sure that your phone and the router you're trying to connect to are up to date.
If you are not running the latest software, or you are not sure, update your Fairphone to the latest Fairphone OS.
Avoid extreme temperatures
Batteries need an optimum temperature to keep the chemical processes inside going. So avoid extreme heat and cold. Do not put your phone in direct sunlight when warm, close to a radiator, or in a fridge. If the temperatures are below zero degrees, keep it inside a pocket as much as possible.
SIM card
Make sure your SIM card is newer than 2 years and undamaged. An old or damaged SIM card may cause your phone's processor work harder to keep up and can even cause unexpected issues.
Long storage
If your battery/device is fully discharged for a long time, it may require up to 20 minutes or more of charging before you can notice any difference. Even more, if you have a weak charger. If you do not see any change after a couple of hours, the battery might not work anymore.
If you store your battery/device for an extended period, keep it at room temperature, and make sure to charge your battery between 50% and 80% every couple of months.
A fully discharged battery could fall into an over-discharged state. This will severely diminish its capacity to hold a charge.
Charge regularly
We recommend to keep the charge of your battery between 20% and 80% to increase its lifespan. So there is no need to always have it topped off to 100%, but also do not wait until only 1% is left!
Optimize your settings
You can use the Quick settings menu to enable or disable some power-consuming features quickly.
Display settings
Your screen requires a lot of energy when in use. By adjusting some settings, you can significantly extend your battery life.
Adjust your brightness
Fairphone has an Adaptive brightness feature. It will optimize the brightness of the screen according to your activities and your environment.
Adjust your screen timeout
To save energy, you can also shorten your Screen timeout. If you set a Screen lock, a shorter interval will also increase the security of your device if you leave it unattended.
- Go to Settings → Display.
- Tap on Advanced and then on Screen Timeout.
- For a good balance, we advise you to select between 30 seconds and 2 minutes.
Wallpapers
Choose a static image (instead of a Live Wallpaper). To select a new wallpaper:
- Touch and hold a blank space on your home screen, and then tap Wallpapers at the bottom.
Connection settings
Data connections can also use up energy. If your mobile signal or Wi-Fi is weak, your phone will consume more energy to stay connected. Move where you have a better signal. Or, if you’re not using it, turn off the data connection.
Wi-Fi, Mobile data, Bluetooth
- Swipe down twice from the top of the screen. You will open the pull-down Quick settings menu.
- Tap the desired icon: Wi-Fi
, Mobile data
, or Bluetooth
Be aware that most of the Coronavirus monitoring apps require Bluetooth to be enabled.
Location service
The Location service can also impact your battery usage. When you don't need it, you can disable it using the quick settings menu.
- Tap the Location icon to enable or disable it. You might need to add the shortcut by tapping on the Pencil icon (as we explained previously in this article).
Some apps or services need to know your position to work. Examples are navigation apps, delivery apps, vehicle sharing apps, geotagging apps, etc.
Airplane mode
An alternative way to conserve energy without completely turning off your phone is via Airplane mode. Note, you won't be able to receive messages or calls while Airplane mode is enabled.
- Tap on the Airplane mode icon
Battery settings
Battery usage
You can see details about what uses the most energy in your phone.
- Go to Settings → Battery.
- Tap on Battery usage.
The graph shows the battery level over a period of time. Below the graph, you'll find a list of the applications and services. The ones that consumed the most energy are at the top of the list.
When you first start using your Fairphone, the battery graph may show gaps or inaccurate information. This is normal - the battery and software will calibrate after a few charging cycles.
Battery Saver
To quickly reduce battery usage:
- Tap on the Battery Saver icon. You might need to add the shortcut by tapping on the Pencil icon.
When Battery Saver is on:
- The battery icon in the status bar on the top will show an orange outline.
- You might get fewer/slower notifications because apps have restricted network usage and background activity. This might also cause the Location services to become less accurate.
