The Fairphone (Gen. 6/Gen. 6+): Frequently Asked Questions
Find support guides, specifications, and troubleshooting steps for the Fairphone (Gen. 6). Select a topic below to view dedicated articles, or refer to The Fairphone (Gen. 6/Gen.6+) User Manual.
General
What are the technical specifications of The Fairphone (Gen. 6)?
What are the safe operating temperatures for The Fairphone (Gen. 6/Gen. 6+)
Why does The Fairphone (Gen. 6) not have an audio jack?
Â
Battery and Charging
How long will it take to charge the battery of The Fairphone (Gen. 6)?
Can I use a wireless charger on The Fairphone (Gen. 6)?
Â
Connectivity
Can I install an eSIM on The Fairphone (Gen. 6)?
What Bluetooth version does The Fairphone (Gen. 6) support?
What USB version does The Fairphone (Gen. 6) use?
Â
Software
What Android version does The Fairphone (Gen. 6) come with?
How long will The Fairphone (Gen. 6) receive software updates?
Is the Fairphone (Gen. 6) compatible with Android Auto?
Â
Camera
How has the camera quality improved on The Fairphone (Gen. 6)?
Can I record 4K@60FPS video on The Fairphone (Gen. 6)?
Â
Warranty
What is the warranty for The Fairphone (Gen. 6)?
Â
Fairphone Moments
How can I customize Fairphone Moments?
Can I change what the Fairphone Moments switch does?Â
Â
Sustainability
Is the Fairphone 6 TCO certified?
Â
