How to attach and install accessories for The Fairphone (Gen. 6/Gen. 6+)
Personalize and protect your smartphone with official modular accessories. This guide covers how to safely attach and install each accessory on the Fairphone.
Before installing your accessories, review the required tools and proper technique below:
- Compatible model: The Fairphone (Gen. 6/Gen. 6+)
- Required tool: Torx T5 screwdriver (included with the lanyard, finger loop, and card holder)
Lanyard accessory
The lanyard lets you carry the Fairphone easily while keeping it handy at all times. The textile cord attaches through a stainless steel and aluminum connection system that screws directly onto the lower back cover of the phone.
- Works with or without a protective case attached.
- Combines easily with the finger loop and card holder accessories.
- Includes a Torx T5 screwdriver in the box for installation.
How to install the lanyard:Â
Loop the nylon cord through the steel ring of the connector.
Unscrew and remove the two screws located at the bottom of the lower back cover on your Fairphone.
Position the metal connection loops at the ends of the lanyard over the open screw holes.
Screw in the new screws included with your lanyard accessory through the loops and into the screw holes until you feel a light resistance, then one-quarter of a turn further. Do not reuse the original screws.
Finger loop accessory
The finger loop helps you maintain a secure grip on the phone while scrolling social feeds, watching videos, or reading on the go. Made from recycled hard plastic and silicone, it replaces the lower back cover of the phone and extends only when you need it.
- Available in three color options to customize your device.
- Works alongside the lanyard accessory and a protective case.
How to install the finger loop
- Use your Torx T5 screwdriver to unscrew the existing lower back cover from the phone.
- Align the finger loop accessory in place of the lower back cover.
- Tighten the screws gently until secure.
Card holder accessory
The card holder replaces the lower back cover of the phone so you can leave your wallet at home. It holds up to three cards, which you can quickly pull out using the easy eject mechanism. Made with a recycled hard plastic back and soft plastic and silicone sides, it adds minimal bulk to your phone.
- Available in three color options to match or customize your phone.
How to install the card holder
- Screw the card holder accessory into place.
Protective case
The protective case provides all-around protection for the phone without compromising style. Raised bumpers around the iconic camera cutout protect your camera lenses against drops and scratches. Built with recycled hard plastic on the back and soft plastic on the sides, it offers a strong and comfortable grip.
- Available in three color options.
- Fully compatible with all other accessories for the phone.
- No screwdriver is needed for installation.
Screen protector
Defend your display against scratches and minor falls with Xensation technology made by Schott. Choose between two screen protector options:
- Standard screen protector: Clear display protection against everyday wear.
- Privacy filter screen protector: Shields your screen from side viewing.
To learn how to attach this accessory correctly, read our guide on how to apply your screen protector.
