Fairphone Repair Request Portal
Here you can find out everything you need to know with our frequently-asked questions about the Fairphone Repair Request Portal!
General
What is the Fairphone Repair Request Portal?
What are the options in the Fairphone Repair Request Portal?
Do you provide a guide for replacing spare parts?
Who are B2X?
Repairs
How do I track my repair?
Will my repair be covered by the warranty?
What if the repair center finds damage not covered by the warranty?
How much will my repair cost?
Can I repair my device at home?
Will opening my device cause damage or affect the warranty?
General
The Fairphone Repair Request Portal makes repairs easier! Learn how to confidently fix issues with your Fairphone device right at home, or opt to send it in to our service centers. You diagnose your device using our portal, then you see your options - either sending the device to us for a repair, or fixing the issue at home with our support.
With it, you can:
  • Troubleshoot interactively: Walk through guided steps to help diagnose product issues.
  • Get clear repair paths: Instantly see next steps, whether it’s creating a repair order or contacting support for more complex cases.
  • Create returns instantly: Eligible customers can submit a return request themselves and get a confirmation number right away.
  • Simplify shipping: Access all necessary shipping instructions, plus a printable label to send in your device.
  • Stay informed automatically: Receive email updates at every step of the process. This means a faster, more transparent, and seamless support experience, available anytime, anywhere.
Enjoy using the Fairphone Repair Request Portal!
The options are:
Send it to us
Sometimes, the problem might be too complex for a DIY repair. Our trusted repair centres are the best way to go in these cases. They will further diagnose the issue in detail before letting you know the next steps. Some repairs are covered by warranty while others are not. We’ll keep you in the loop if there are any costs involved, and only proceed with your approval.
Do it yourself
Some repairs are easy and much more convenient for you to do in the comfort of your own home. We recommend diagnosing the issue first, as some repairs are covered by your warranty. What you’ll need to repair at home: the relevant spare part, a Phillips 00 or Torx T5 screwdriver, and the right repair guide.
We do! You can go to our detailed repair guides, and select your device from the drop down menu. From there, you can see how to replace a spare part. If you need further help, you can diagnose issues in our portal.
Who are B2X?
In the Fairphone Repair Request Portal, it says "powered by B2X". B2X are our partner company who supports with the repair request portal! The portal is an authorised service by Fairphone.
Repairs
You can track your repair by entering the job number or serial number in our Repair Tracker.
When you send your device for repair, the repair center will perform a full inspection and diagnostics. If we find no signs of accidental or cosmetic damage, and your product is still within our standard or extended warranty period, then yes, your repair will be covered!
If the repair center finds damage not covered by our warranty, they will send you a quote for the repair costs. You will then have the following options: Accept the quote and pay for the repair, or Pay for shipping to have your device returned unrepaired, or Abandon the device for free recycling.
If your repair is covered by our standard or extended warranty, it won’t cost you anything! For repairs not covered by our warranty, the repair center will send you a quote based on our price lists, found here for phones, and here for audio devices.
Absolutely! We encourage you to repair your Fairphone yourself. To ensure you get the correct solution, we strongly recommend first diagnosing the issue at home. This will help determine if the repair is covered by your warranty and/or if it's something you can easily fix at home. Once you've diagnosed the problem, you can explore our detailed guides and find spare parts readily available on our website. If you're still unsure which part to order or how to proceed, our customer support team is always ready to assist you.
We’ve designed our products to be easily repairable, and if you follow our instructions carefully, performing DIY repairs shouldn’t cause damage or void the warranty.
