My Fairphone battery will not charge
If your phone will not turn on or charge, this article outlines your next steps. You might need to test your charging equipment or perform a battery kickstart.
Step 1: Clean the charging port
Lint, dust, and dirt can slowly collect inside the charging port of your device. This prevents the charging cable from making a secure electrical connection.
Follow these steps to safely clear debris from your charging port:
- Turn off the phone: Power off your device completely before you begin the cleaning process.
- Use a non-metal tool: Try to clean the port with a sharp plastic or wooden pick. Do not use a metal object, like a needle or safety pin, as metal can permanently damage the sensitive electronic contacts inside the port. Be gentle to avoid causing additional damage.
- Clear out the debris: Another option is to clean the port out by blowing some air into it. If you have a can of compressed air, you can use that to clear out the loosened debris.
- Test the connection: Plug in your charger without the protective case or back cover attached to see if the device begins to charge.
Step 2: Perform a forced restart
If cleaning the port does not help, the phone system might be frozen in a black screen state. A forced restart cuts power to your smartphone and forces it to restart.
- Connect your device to its charger.
- Press and hold the Power and Volume Down buttons at the same time for roughly 15 seconds.
- Watch for a slight vibration or a brief screen flicker indicating the phone is starting up.
Step 3: Verify the software version
An outdated system can cause power issues.
Connect your phone to a Wi-Fi network and navigate to Settings > System > Advanced > System update to check for and install any available updates.
Step 4: Test your charging equipment
Faulty or weak accessories often cause charging issues. To rule this out, follow these verification steps:
- Try three different chargers: Test at least three different chargers and three different cables. Some chargers do not deliver enough power to the phone.
- Use recommended specifications: Ensure you’re using the correct charger type for your Fairphone.
- Charge via computer: Connect your smartphone to a computer to check if the computer recognizes the device or charges it.
- Remove accessories: Charge the phone without the protective case or back cover. Removing the back cover ensures the USB connector has a better fit into the charging port. If this fixes the issue, you might need to buy a new cable.
Step 5: Perform a battery kickstart
If your battery is completely empty, the phone may seem completely dead. Follow these exact steps to kickstart a drained battery:
- Remove the battery: Power off your device, remove the back cover, and take out the battery.
- Wait 30 minutes: Leave the battery out of the phone for half an hour.
- Reinsert and connect: Put the battery back into the phone and connect the phone to your charger.
- Check the indicator light: If the charging light blinks, the battery was totally empty. Wait a few minutes until the light becomes steady.
- Monitor the screen: A loading battery icon should appear for a few seconds. You can press the power button quickly to display the icon. Keep the phone charging for more than one hour.
Still need help?
