How to use a Fairphone gift card
If you received a Fairphone gift card, you can redeem it at checkout when ordering from our online shop. Here is how to apply your code to your next order.
What to know before using your card
- Your gift card is valid for 36 months (three years) from the date of issue.
- You can use up to 10 gift cards in a single order if the order total is greater than the balance of the first gift card.
How to redeem your gift card at checkout
- Visit our online shop and add your chosen items to your cart.
- Open your Cart.
- Locate the Gift Card/Discount code field on the right side of the order summary.
- Enter your unique gift card code.
- Select Enter.
- Confirm that the amount was deducted from your total balance.
- Select Continue checkout.
- Fill in your delivery details in Checkout and select Save.
- Select your preferred shipping option and select Continue to review and pay.
- Pay any remaining balance to complete your order.
After completing your purchase, you will receive an order confirmation and an invoice email showing the gift card code used and the amount applied.
Still need help?
If you still require assistance, reach out to our customer support team. You can also open a support request directly through the My Fairphone app pre-installed on your device.
Frequently asked questions
Can I use my gift card more than once?
Yes. If your order total is less than the total value of your gift card, the remaining balance stays on your gift card for future purchases.
Can I use multiple gift cards on a single order?
Yes. You can use up to 10 gift cards on a single order, provided the order total is greater than the value of the first gift card applied.
What happens if I return an item bought with a gift card?
Contact Customer Support to process your return. Our support agents will either top up your existing gift card balance or issue a new gift card for the refunded amount.
Can I use a gift card to purchase another gift card?
No, gift cards can be used to purchase anything in our online shop except for other gift cards.
