How to connect headphones and audio equipment to your Fairphone
  • Region:Europe
  • Updated
Connecting headphones or external audio equipment to your Fairphone is quick and simple. This guide explains how to connect wired or wireless audio equipment across all Fairphone models, choose the right adapter, and fix audio port issues on older models.
Ways to connect your audio equipment
  • Wireless Bluetooth connection: Pair your Bluetooth headphones or external speakers directly on your phone under Settings > Connected devices > Pair new device.
  • USB-C headphones: Plug digital USB-C headphones directly into the USB-C charging port on the bottom of your phone.
  • USB-C to 3.5mm adapter: Connect a USB-C adapter to the charging port so you can keep using standard 3.5mm wired headphones.
Why newer Fairphone models do not have an audio jack
Removing the traditional 3.5mm audio jack gives us space inside the phone to make key hardware improvements. Without this opening, we can fit a larger battery, design a slimmer smartphone, and preserve room for repairable spare parts. Removing the port also helps seal the phone against water and dust, allowing modern models to reach IP ratings like IP55 on Fairphone 4 and IP68 on Fairphone 5. Moving audio to the USB-C port and Bluetooth connections lets us build a more durable phone that lasts as long as possible.
Audio connections by Fairphone model
Fairphone model Built-in 3.5mm audio jack USB-C audio support Bluetooth support
Fairphone (Gen.6/Gen.6+) No Yes Yes
Fairphone 5 No Yes Yes
Fairphone 4 No Yes Yes
Fairphone 3+ Yes Yes Yes
Fairphone 3 Yes Yes Yes
Fairphone 2 Yes No (Micro-USB port) Yes
Fairphone 1 Yes No (Micro-USB port) Yes
How to fix built-in audio jack issues on Fairphone 3 and Fairphone 2
If sound is missing, distorted, or playing out of only one ear when using the built-in 3.5mm audio jack on a Fairphone 3+, Fairphone 3, or Fairphone 2, follow these steps to resolve the issue:
  1. Plug in a different pair of wired headphones to confirm the cable or 3.5mm plug is not damaged.
  2. Inspect the audio port and carefully clean out any dust or pocket lint using compressed air or a wooden toothpick.
  3. Restart your phone to clear temporary software glitches.
  4. If the port remains non-functional due to hardware damage, you can replace the top spare part yourself. Thanks to our modular architecture, you do not need to replace your whole phone—you can simply order a replacement top spare part from our online shop and complete a quick self-repair.
Still need help?
