Charge your Fairphone
Find out if you can use your existing cable and charger, and how to safely charge your Fairphone's battery.
Check if your cable and charger is compatible
For the best results, we recommend using our Dual-port 30W charger and USB-C to USB-C cable. We've designed these to work perfectly with the Fairphone 3 and above.
Third-party cables and power adapters may work, but it's important to make sure they are compatible with your Fairphone to charge it safely. You can usually find the technical specifications of your equipment on the packaging, or by checking the website of the manufacturer.
To check if your third-party charger and cable is compatible, choose your phone below:
Cable
  • Use a high-quality USB-C to USB-C cable that supports a minimum of 60W (20V and 3A).
Charger
  • Use a high-quality USB Power Delivery (USB PD) charger that supports PPS at a minimum of 30W (9V and 3A).
  • Or, use a charger that supports Quick Charge 4.0 or above.
Cable
Charger
Cable
Charger
Cable
  • Use a high-quality MicroUSB (Micro-B) cable.
Charger
  • Use a 5 volt (5V) charger with a minimum current of 1 ampere (1A, 1000mA).
Charge your Fairphone's battery
Your Fairphone comes with a removable, lithium-ion battery. To charge your Fairphone's battery:
  1. Connect one end of the charging cable to our Dual-port 30W charger or a compatible third-party power adapter.
  2. Connect the USB-C end of the cable to the charging port at the bottom of the Fairphone.
  3. Connect your power adapter to a power outlet.
Frequently asked questions
Can I charge my Fairphone wirelessly?
No, it's not possible to charge your Fairphone wirelessly. Current data suggests wireless charging is less efficient than wired charging. Depending on further development of this technology, it could be something we consider in the future.
How can I maximize my Fairphone's battery life?
We've put together some tips to help you get the most out of your Fairphone's battery: Maximize your battery life.
Why is there no cable and charger included in the box?
Fairphone was one of the first smartphone manufacturers to actively reduce e-waste by not including a cable or charger in the box.
There's a good chance you already have a cable or charger at home, and you can find out if they are compatible here: Check if your cable and charger is compatible.
If you want to know more about this decision, watch the first episode of Ask the experts.
How can I tell if my Fairphone is charging?
When you plug in your Fairphone, the display will light up and show the current battery percentage.
You can also turn on charging sounds and vibration:
  1. On your Fairphone, go to Settings → Sound & vibration.
  2. Tap Charging sounds and vibration to turn on or off.
Why is my Fairphone charging slowly?
There are a few reasons your Fairphone may be charging slowly. Make sure that you:
Tip: It's normal for your Fairphone's battery to charge slower once it reaches 80%. This helps extend the battery's lifespan.
My Fairphone has stopped charging
There are a few reasons your Fairphone may have stopped charging. Make sure that you:
Due to a high volume of requests, we have limited our chat opening hours to assist as many customers as possible. If you have an open request, please know we are working hard to get back to you as quickly as we can. For urgent matters, direct support is still available on Thursday and Friday from 09:00 to 12:00. Thank you for your patience.
